Question about Panasonic DMR-ES35VS
Push on button dvr says set 2
Remote turns on tv not dvr displays set 2 in LED screen, no navigation possible from remote, fresh batteries. The buttons on the front work, but the remote just makes it say "set 2."
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Press ENTER and number 2 together on the remote control for at least two seconds to restore control.
Posted on Apr 21, 2009
  • Heather Apr 30, 2012
    Modal DMR-ES35V
    If You have Set 1 do the following
    Press "Enter" and Number "1" together on the remote control Till u see your Digital Cloak Flash once u do congrats your remote Works like brain new *Cheer Dance*
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
My samsung 3D led multisystem smart TV remote control does not work anymore
  1. TV off
  4. Turn on TV
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Remote will not work
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Mar 05, 2014 | Samsung TV Remote Control
Samsung tv has never responded to the remote control
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Feb 15, 2014 | Samsung TV Remote Control
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Try this:
  1. TV off
  4. Turn on TV
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
TV IS NOT RESPONDING TO REMOTE. I'VE CHANGED THE BATTERIES AND HAVE TRIED OTHER SAMSUNG REMOTES THAT WORK ON MY OTHER TVS. ANY SUGGESTIONS...
Sounds like problem is with TV. Make sure the remote sensor on the TV is not blocked, it is located at the lower right part of the front of the TV.
Dec 12, 2010 | Samsung BN5900696A Remote Control
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
My dvr remote 2 has been taken over by my other tv2 remote is there a way activate the former remote? I just had a hdtv dual dvr installed and a new dual reciever. I already had a dual dvr. When I had the...
Unplug one of the receivers. Now go to the second and with the TV1 remote press MENU-MENU and you will see the two remote addresses displayed. On the TV 2 remote that is associated to turn off the TV2 with this receiver press and hold the SAT button on the top left of the remote until all the buttons across the top illuminate. Now key in a two digit number that differs from the one for TV2 displayed on the screen. Now press the pound sign and the SAT button will flash three times. Next press the small record button until the TV2 address changes to the correct two digit number. Now you should be able to turn the other receiver back on and be able to control each TV2 independent of each other. Thanks for using Fix Ya. If you need further assistance let me know.
Sep 17, 2009 | DISH Network IR Remote Control
Tv turns off when it feels like it
There are 4 possibilities.
1. weak remote batteries
2. failing remote button pad
3. failing infra-red LED in remote
4. failing infra-red receiver in TV.
First, try another fresh set of batteries.
Next, replace the remote, third, have a TV shop look at it.
May 12, 2009 | Mitsubishi VS-45609 TV
How to reset (manually) factory defaults?
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
Sincerely,
Michael Scott
Nov 16, 2008 | Protron PD-DVR100 DVD Recorder
Panasonic DMR-ES35VS Logo
295 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
