Question about Casio FX-300MS Calculator
Casion Fx-300MS Hi, whenever i try any math equation, this calaculator would round it up. For example. 6/5 would turn out to be 1. Thank you, I need this fixed soon so i can use my calculator in class
  • Casio Master
  • 8,016 Answers
If I understand correctly you result do not display any decimal.
If you want a fixed number of decimal digits (exemple 2) Press the [MODE] key a number of times until you reach the screen that displays Fix Sci Nom and under them the numbers 1 2 3
Press 1 to choose Fixed format followed by 2 for TWO Digits
3 decimal digits [MODE] ---------[1 ] (Fix) 3
Hope it helps.
Posted on Sep 25, 2009
On my casio fx-83GT PLUS calculator whenever i use the inverse cos,sine and tan function math ERROR comes up how do i fix this
The inverse cosine function is defined for arguments from -1 to +1. 6 is outside of this domain, thus the error. Do you get an error if you try the inverse cosine of 0.6, for example?
If you're getting the same error for the inverse tangent, could you post an example?
May 12, 2014 | Casio FX83ES Scientific Calculator
Examples of homogeneous differential equation
Hi janeth sabay,
Have a good day!!
Here is your needed example for Homogenous differential equation:
The equation 49e8abf8a1c5be91fadbf33a5405bdc3.gif is said to be homogeneous if P and Q are homogeneous functions of x and y of the same degree.
We can test to see whether this first order equation is homogeneous by substituting 21fe29cd49ecbd3abe2ae6373e89eab6.gif . If the result is in the form f(v)i.e. all the x's are canceled then the test is satisfied and the equation is Homogeneous.
Example 1:19c981882c1f9b05fadf586b56a931bc.gif(2)
There are no terms in x on the right hand side and the equation is Homogereous.Example 2:72f80f87eb510a9e0fd81c423b3faa55.gif(4)
So the original equation is not homogeneous.Methods Of Solution.
A solution can be found by putting y = vx on both sides of the equation:-
Example 3:
Putting y - vx
Since y is a function of x so is v
Separating the variables
Integrating
Substituting (12) in equation (10)
405d0e82aab0e4cb688a90b92a0dab77.gifI can suugest you also to visit this site for more examples http://www.codecogs.com/reference/maths/differential_equations/homogeneous_differential_equations.php
Sep 12, 2011 | Toys
How can I invert a number in Casio fx-82ES?
Use the "x^-1" ("x-superscript-negative-one") key just below and right of the big round cursor pad.
For example, to invert 2, press 2 x^-1 =
Aug 15, 2011 | Casio FX-300MS Calculator
Im trying to graph a parametric equation and whenever the equation has an exponent/power in it the calculator says Syn error so i know how to graph x=2 cos T, y=2 sin T and similar equations without a...
To enter powers of trigonometric functions you must enclose the functions in parentheses and then apply the exponent to the whole. For example X1t =(sin T)^3 , Y1t=(cos T)^3 will give you a shape similar to a rhombus with concave sides. The symbol ^syands for the operation of raising to a power. The key is the one with the caret symbol ^ , and it is wedged between the xsqure and EXIT keys (third row of keys).
As regards the cotangent, use the equivalent definition cot(X)=1/tan(X).
Jul 26, 2011 | Casio FX-9750GPlus Calculator
I need straightforward key strokes for a casio fx115 es graphing calculator to solve linear equations. I have the Manuel but it only confuses me. this is an example of what I'm solving ...
This calculator doesn't really support a solver like that. You can use Woflram Alpha to solve equations like that really quickly. Example
There are more expensive calculators that will solve these types of equations, but I would recommend just using Wolfram Alpha whenever you need a solution to a math problem.
Mar 02, 2011 | Casio FX-115ES Scientific Calculator
I'm just beginning to learn about trigonometric functions (sin, cosine & tangent). My math book says for a problem such as "4 cos 75.8", I should press 4, x, 75.8, cos, = (in that order)....
Try 4 x cos 7 5 . 8 =
The fx-300MS is a more advanced calculator than what the book is describing. It evaluates cosine(x) as cos x rather than x, cos.
Nov 02, 2010 | Casio FX-300MS Calculator
Please explain how to get 2.3 times 10minus 4 to come on screen
1. First enter 2.3 followed by ' ( '.
2.Then enter 10 - 4 and close the bracket ' ) '.
The equation on the screen should look like 2.3 ( 10 -4 ).
Thank you.
Jun 14, 2010 | Casio FX-300MS Calculator
HOW DO I CHANGE MY MODE TO REGULAR MATH EQUATIONS FROM SCIENTIFIC NOTATIONS AND EGINEER NOTATIONS ,WHAT HAPPEN WAS IM A STUDENT IN COLLEGE ,AND MY TUTOR WAS DOING SOME EXAMPLES ON SCIENTIFIC NOTATION AND...
Press [SHIFT][MODE][6:Fix] and press a numbetr between (0--9). The number you select will be the number of decimal places your results have.
However if a result is smaller than 0.001 it will be in scientific notation.
Hope it helps.
Oct 09, 2009 | Casio fx-300ES Calculator
Fractions
there is a A b/c button. This is the button use to enter fractions. so 4/3 would be entered as 4 |A b/c| 3
If you want to have the answers in fractions as well, then I believe you hit more a few times. And then there should be a display option, in the display option, there should be a b/c. This will show your answers in fractions. Hope it helps
May 05, 2009 | Casio FX-300MS Calculator
Casio FX-300MS Calculator Logo
283 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
