Question about Maytag Neptune MAH5500B Front Load Washer
Maytag dryer performing inconsistantly
3 yr old heavily used dryer now only works adequately about 1/3rd of time
other times it tumbles with NO heat or very low heat even on highest settings (used to be too hot @ this high setting!)
had repair man out who checked for adequate ventilation ,cleaned filter etc & could not find anything wrong
he did NOT replace anything & (no surprise!) the problems remain
I have a few months left on my warranty & want to be proactive in getting the necessary replacemnt part(s) for more consistant & higher heat.
As the repairman seemed clueless re troubleshooting ideas I need your help with suggestions of poss problem & how to fix
  • 20 Answers
You either need a new heating element or you are not getting full 240 volts, im assuming its electric here. check your outlet to make sure both leads are hot.
Posted on Feb 13, 2009
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
Life span of a dryer
the first thing you should do is clean out any lint in the exhaust side of the venting area. it could be overheating from that and shutting the heat off too soon.. on an electric dryer the heater part either works or it doesnt. element should be fine in this case i suspect..
Apr 01, 2017 | Maytag Dryers
Dryer keeps going out - 3rd time since January. It tumbles but no heat. I've replaced the thermal cut off #279816 and the element #279838. I cleared out the vent all the way to the roof. I've...
Hello this will be a bit of an odd question at first but have you ever dlinted your dryer? Just as your dryer vent does get a build up of lint the dryer does as well. Click this link to view a tip I wrote the most important area to clean is where the blower goes into and you get at this area by removeing the rear panel of the dryer if your dryer is a type like whirlpool, kenmore, maytag all dryer need to be dlinted at least once per year to maintain the dryers ability to dry. If I am able to bring a 45 year old dryer back to life by doing this you should have no problem If you have any questions message me back this will require also the tub being removed as well but I can guarantee if the air is unrestricted the heat is able to travel unblocked and it doesnt cause blown thermistors as well . Thanks Rick
Aug 10, 2011 | Dryers
Will not dry
Does it get hot?
Dryers have 3 functions to perform:
Air flow
Controlled heat
Test for each, and fix the one that is not functioning. Remove vent tube to test for air flow.
Nov 05, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Simpson Maxidry 1200 S Cloths Dryer. Our dryer whilst spiining and heating is not adequately drying clothes. When I took it down to check test it appears that the belt to the central lint fan may have been...
Yes - the vent exhausts humid air, and draws IN fresh dry air. So the humid air is staying trapped in your unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 08, 2009 | Washing Machines
Dryer won't heat up! It tumbles fine, but no heat! My Maytag dryer is only two or three years old!
This problem is normally caused by a faulty thermostat and or heating element. Test and replace if needed
Sep 23, 2009 | Maytag Dryers
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
Aug 25, 2008 | Whirlpool GEW9200L Electric Dryer
Condenser dryer cutting out
There is typically a thermal heat sensor AND a thermal trip. I suspect the heat sensor is fluffed up too...
Oct 10, 2007 | Bosch Axxis WTL 6003 Electric Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
