Canon EOS 30D Body Only Digital Camera
Problem for Canon EOS 30D Body Only Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
By mowkeena on Feb 13, 2009
My Hitachi 4GB Microdrive CF card was full. I ordered new (refurbished) ones online. When I put one in my camera the screen read "Err CF". From the menu I selected format > ok. Screen read "Err 99". I tried another one of the new cards, same thing. I put my old CF card back in and deleted a few photos to make room to take more pictures. Everything worked normal. Placed the new refurbished ones back in and got the errors.
I have taken the lens off. The battery out. The CF card out. Let the camera sit for 20 or more minutes with all of those items out and systematically replaced them and checked if I got the errors. I was sure to use a fully charged battery. I only got the errors when I used one of the new CF cards. I have cleaned all the sensors. Checked for bent pins. I can't think of anything else.
I then returned CF cards to the seller (whom I have bought the exact same thing from in the past and not had a problem) for a replacement. While I was waiting for the replacement cards I ordered a few other CF cards from a different seller. I got them today. Same problem, same errors. Tried all of the same things again and same results.
Is it possible that ALL the cards are faulty? Is there a setting on the camera that I have set that prohibits formatting of the CF cards that I am not aware of? If the model number is the same on all the cards is it possible that they are versions that are not compatible with this camera?
Any ideas welcome. Thanks.
Best Solution
posted on Mar 19, 2009
Very Helpful)
JohnLeF
Rank: Guru  Canon Expert
Rating: 90%, 100 votes
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon EOS 30D Body Only
Questions and Unsolved Problems for Canon EOS 30D Body Only
Do you recommend Canon EOS 30D Body Only Digital Camera?
Answer
Answer
When I try to view images on a tv the connection in the camera does not hold and the image does not... (More)
Answer
Describe your how to fix the light meter inside canon 30d slr Problem
Answer
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly... (More)
Answer
after beep sound of focusing,shutter is not clicked
Answer
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon EOS 30D Body Only...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
