Question about Toro Lawn Mower With Toro Power Tools
Frozen blade spindals
I have a 2007 toro lx425 just bought it it is new but was sitting out side and was never used runs fine but the deck spindals will not turn ? will a little heat help ??? papas yards (
  • 1,902 Answers
Yes apply some heat and it will break it lose and the system will spin just fine
Posted on Feb 13, 2009
My Toro LX425 riding mower will not start has been fine all season; battery indicator light on but wont turn over; starter?
First make sure your battery is fully charged. The charger on lawn tractors will not keep the battery fully charged as they just produce a light charge. Check battery before the starter but if battery is fully charged then it's possible the starter could be bad.
Oct 15, 2016 | Toro Garden
Toro zero turn will not turn over
How long has it been since last running? Are all the safety switches activated? Handles pushed back all the way? Sitting on seat (i presume) ? Parking brake engaged? I would also check the oil. What does the oil look like?
Sep 28, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How do i adjust the deck on my toro lx425 riding mower? it is cutting the grass too low.
On the right side of your mower you should find a lever that allows you to adjust the cutting height of the deck up and down.
I hope this helps, if that is not sufficient just reply for some clarification and I will answer you question further.
Jul 15, 2011 | Garden
Lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
Jul 14, 2010 | Toro Garden
RE: 42'' zero turn Toro with Kohler 19 hp. Ever since I bought it new, it has used oil, I am very dissatisfied with it. Model 74360 Serial #270000001. The starter relay doesn't work correctly. It will not...
Toro is a great brand, but the Home depot models are for home use. IF it won't start correctly you should troubleshoot the problem as this is a built in safey system for your benefit. There is a switch on both parking breaks, A switch to detect you sitting in the seat. The PTO must be disengaged. Check each of these. If you have your manual you can view the schematic diagram, and test each switch. If not, you can download a manual from Toro web site. According to your model and serial number your deck would only have two blades. They also have what they call "blade stiffeners" . Your results from buying power equipment from a big box store is typical. If you need service, pay a little more, and buy from your local power equipment distributor.
Jul 12, 2010 | Toro Garden
I have a Toro zero turn commercial 60" model 74272 which throws the deck belt as soon as the clutch is engaged. I have replaced every pulley, spacer, spring,etc, as well as a new belt. Also, everything is...
im no expert but had a similar problem with an old craftsman mower. the belt keeper which is an L shaped piece of hardware located at the back of the deck next to the idler pulley spindal. Also could be the deck is cockeyed and needs to be leveled or the wrong v-belt.
May 25, 2010 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
How do I get instructions on replacing both upper and lower drive belts on a LX425 Toro Lawn Tractor?
You can go to and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Oct 25, 2009 | Garden
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lx425 rider mower wont start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Oct 05, 2008 | Garden
Toro Lawn Mower With Toro Power Tools Logo
152 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
