Question about HP Officejet Pro L7680 All-In-One Printer
I CAN'T PRINT INVITATION SIZE (4.5" X 5.6" APPROX) USING HPL7680
Even custom sizing won't allow for that size. It was super easy to do any size envelope with the HP 6100. Now that we've "upgraded," I have nothing but problems with envelopes.
  • HP Master
  • 419 Answers
Unfortunately you've posted this under the wrong printer model so I can't offer any detailed help (I'd suggest you repost under the correct model number in future).
That said, HP officejet printers have a history with paper feeding and yours may be no different.. Small or envelope style media may be prone to jamming or problems with the rollers failing to pick up the media.
If this sort of printer is essential to you I would recommend getting a different printer like a Canon iP4500 or similar... The rear path and envelope handling on those models is significantly better although it's not so clever at recognising all media sizes as well as I'd like.
Hope that helps.
Posted on Feb 13, 2009
I am trying to print a wedding invitation on 5.5" x 8.5" paper and I keep getting paper size problem.can the HPC5180 print that size paper
3 in x 5 in (min) - Legal (8.5 in x 14 in) (max) is the spec per HP. Have you tried to set up the paper size as "custom" in both the driver and the program? This may help if the size you want is not listed in the properties dropdown.
Jun 17, 2010 | Office Equipment & Supplies
Hello, I have an invitation that is 4in wide x 9 inches in height. I want to print something on it, but not sure how to get my printer to recognize that I am using custom size paper. It keeps printing on...
In addition to the wide variety of standard paper sizes available for this printer, you can use custom size paper in the Tray 1 (MPT).
The size range for custom size media is as follows:
    Minimum allowable page size:
    89 x 140 mm (3.5 x 5.5 in.)
    Maximum allowable page size:
    216 x 356 mm (8.5 x 14 in.)
  1. Open Tray 1 (MPT).
  2. Insert the custom size paper and adjust the guides to match the size of the paper. Place the side to be printed facedown with the top of the page entering the printer first.
  3. When the front panel prompts you to confirm the type and size of paper:
    1. Scroll to Change by pressing the Down Arrow key and press the OK key.
    2. Scroll to the correct paper type and press the OK key to save your selection.
    3. For the paper size, scroll to Custom and press the OK key.
    4. Select Set Custom Width (W) by pressing the OK key.
    5. Press the Down Arrow or Up Arrow key to scroll to the desired value for X and then press the OK key.
    6. Scroll to Set Custom Height (H) and press the OK key.
    7. Press the Down Arrow or Up Arrow key to scroll to the desired value for Y and then press the OK key.
  4. Select the custom size in the printer driver.
  5. Windows 95 / Windows 98 / Windows Me PostScript driver: On the Setup tab:
    • After you select the Multi-Purpose Tray and the tray displays Custom to indicate that it has custom size paper, enter the dimensions of the custom size paper in the Width and Height boxes.
    • If you select Automatic for the paper source and select Custom Size for the paper size, enter the width and height values of the desired custom size paper in the Width and Height boxes. The values for width and height are initially 0. If you previously entered information in the boxes, the values are automatically entered.
    Windows NT / Windows 2000 / Windows XP PostScript driver: On the Paper/Quality tab:
    • If you select Choose Specific Tray, select the Multi-Purpose Tray.
    • If you select Automatic, you can select your custom size from the Paper Size drop-down list.
    • Click My Custom Sizes and highlight the custom size in the Current Selection list. The Name, Width, and Height boxes display the details about the highlighted custom size and the sample image changes to represent a scaled version of the custom size.
    • To create a new custom size:
      1. Click New.
      2. Enter the new name in the Name box.
      3. Enter the dimensions in the Width and Height boxes. The sample image changes to represent a scaled version of the new custom size.
      4. Click Save to add the new size to the list. Click Cancel to exit without saving the new custom size.
      5. To exit, click Close.
    • The My Custom Sizes box lists existing custom sizes that are supported by the current printer. Since these custom sizes are saved in your computer's operating system, they are available for you to select in your applications.
    • If you create a custom size in certain applications, the driver lists the custom size automatically.
    MacOS 8 / MacOS 9 driver:
    • In the Page Setup dialog box, click on Page Attributes, and select Custom Page Sizes. Then press New to enter a new custom page size. A dialog box appears where you can enter the width and height, margins, and name of the custom page size.
Jan 19, 2010 | Xerox Phaser 6250 Laser Printer
Mismatch paper size error
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print
on the bottom of that screen there should be a scale to paper size drop down box. Scroll to the bottom and your saved name and dimensions should be there.
You will have to setup each individual sized template ones and then just scale to fit each time. Hope this helps
Mar 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
Need to print a half-fold card envelope with HP Photosmart C4480
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
Thank you for taking my question: HP laserjet print using Vista
go to printer propeties and check paper size ther'l be a custom size click on that n feed what u wnt
Dec 11, 2008 | HP DeskJet 880c InkJet Printer
Hp 6310 officejet
Check the paper size setting when you set up the printer. Check page setup in File menu and specify the page size.
Dec 01, 2008 | HP Officejet 6310 All-In-One InkJet...
Paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on custom
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Epson Stylus Pro 2200 printer help
I have the same problem with custom sizes. Also, some sizes are unavailable. I did get a custom size working by setting the margins to .25,.25,.25,.45,
Apr 13, 2008 | Office Equipment & Supplies
Printing envelopes on the bizhub 252
After spending way too long messing around with this on my bizhub 250 here's what finally allowed me to print:
I simply changed the bypass tray setting from "envelope" to "normal". I kept the custom size the same (9 1/2 X 4 1/8) and it started to print.
Doesn't make sense, but you can give it try.
Dec 27, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
HP Officejet Pro L7680 All-In-One Printer Logo
178 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
