Question about Whirlpool Duet GHW9150P Front Load Washer
Fabric softener chamber is closed design! Impossible to work!!!
I have to remove the entire tray from the machine, lift a part out to get the fabric softener where it can get into the system, every time I wash. There's a mistake in the design it looks like to me.
    President:
  • Whirlpool Master
  • 2,651 Answers
??????? they tray comes out easily, but your saying it clogs after each use??? not na common issue, please clarify to help you further.. it is normal for the unit to retain water after cycle complete( especially if fabric softenerwasnt used in prior wash) the compartment floods and siphons each chamber during wash, so if its there no fabric softener in to "siphon out" the waterwill reamin in chamber. normal operation
Posted on Feb 13, 2009
My Washing machine hotpoint aquarius WDPG 8640 will not take in fabric softener
It is likely that the tray need removed from the machine and the back side of the drain cleaned. Over time the softener can build up and eventually plug off from the back side. So just cleaning the tray won't clear the problem.
Jun 21, 2016 | Hotpoint Washing Machines
After filling compartments correctly and closing the tray, I see the fabric softener emptying into the washer. Tray does not leak softener when removed and filled.
You are putting too much in there... the tray empties on a siphon priciple... if you fill it too high it will just siphon out...
Use less fabric softener...
heatman101
Dec 13, 2010 | Kenmore Elite HE5t Washer
The fabric softner chamber seems to be clogged because after a wash it is full of water.
The fabric softener chamber is likely full of crud and or mildew.
  1. Pull out the detergent / softener tray (press down on the tab in the back to get it all the way out). Take it and wash it as well as you can.
  2. Now, pull the washer out enough that you can get to the back of the machine.
  3. Unplug the washer!
  4. Remove the four screws holding the plastic tabs (at the top) on the rear of the machine.
  5. You should now be able to remove the top cover of the machine - slide it back and then up.
  6. There are four small hoses connected to the back of the detergent tray, and one large hose.
  7. Take a marker / tape / etc. and label these hoses 1,2,3,4 - write the corresponding number on the top of the detergent tray so you will know where to hook them back up!
  8. Using pliers, squeeze the tabs on the small clamps to loosen them enough to pull them back about an inch on the small hoses.
  9. Pull the hoses off, gently.
  10. Use a phillips head screwdriver to loosen the clamp on the large black hose. Pull it off.
  11. You may want to loosen the other end of this large black hose and remove the hose for cleaning. Mine was nasty.
  12. There is a black bundle of wires snapped into the sides of the detergent tray. Take this bundle out of the clips so it hangs loose.
  13. Remove the two screws from the front of the detergent tray. These are on either side of the opening and are usually hidden by the detergent drawer.
  14. Now, you should be able to slide the entire fabric softener tray back and out of the machine.
  15. The tray comes apart into two pieces - gently pry the tabs on the sides to separate them.
  16. Clean everything! If anything is too nasty / clogged to clean, buy a replacement part.
  17. Reverse steps to reassemble and good luck!
Apr 29, 2010 | LG WM-2277HW Front Load Washer
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
Fabric softener not dispensing
Fabric softner trays often clog up, because a little soap powder in the tray by accident tends to block it. If you pull the soap tray out as far as it will go, you will see that there is a bit of the tray right at the back, probably on the left with an arrow or thumb print or indentation in it. If you press down on this it is a catch and it will allow you to remove the tray from the machine completely. Once out of the machine, the fabric softner cover will also lift out. Clean everything throroughly (Tak it outside and turn your garden hose full pressure on all the holes on the tray and then scrub it out with a toothbrush. Put the fabric softner tray mabc in and slide the soap tray back in the machine. This should have fixed it.
Mar 01, 2009 | Whirlpool Washing Machines
My front loader Bosch washing machine is not draining in the fabric softener section.
Make sure it is the fabric softener that is not being added. Try running w/o fabric softener and see if the tray is still full. The reason I am asking is that after I run my washer the fabric softener tray is full, with water, not softener. The factory tells me it is because the water fill nozzles have realigned and overspray into the softener tray. Not a big problem, since my system is under warranty I am having them fix the nozzles and then I will know how to redirect.
If it is the softener that is not being added then check to make sure the line is not clogged. You can lift out the bleach / softener try and check for cloggs.
Aug 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Detergent dispenser tray will not open
we have been having the same issue - it's possibly the fabric softener blue 'cover' that becomes raised to hit the top of the dispenser unit
we took the top cover off the washer & my husband lifted the dispenser unit lid (as much as possible) and I was able to pull out the dispenser tray
we just removed the cover for the fabric softener so it won't happen again!!!
Jul 25, 2008 | LG WM2277HBW XL Front Load Stackable...
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
