Question about Hudson Rci T UPDRAFT II NEB MOUTHPIECE TUBE HUD1732 - T UPDRAFT II NEB MOUTHPIECE TUB
Hudson nebulizer leaks
My daughter's nebulizer doesn't mist anymore, it spits the medication out of the mouthpiece! Can this be fixed?
  • 5,568 Answers
If tap water is used, you may have a buildup of lime deposits; allow it to dry and then look for any white deposits.
Using distilled water will avoid this.
Posted on Feb 13, 2009
Nebulizer omron mist coming out most of the time but it takes very long for medication to finish
Nebulizers are a slow steady way to administer inhalation medication. the whole idea is that you have to slow down, relax and breath regular and steady to get all the medication. just a side note make sure you clean the face mask on a regular basis because they are great places to grow mold and bacteria. hope it helps.
Nov 19, 2017 | Omron Health & Beauty
How often should the Micro Mist Nebulizer be discarded and why?
Every two weeks. If you wash in a solution of one part distilled white vinegar to three parts water once a day it can last much longer. Vinegar is a great disinfectant and will reduce the chance of infection. Most people are slack at this cleaning process hence the normal disposal of the kit at two weeks.
Apr 28, 2010 | Hudson Rci 1 OF MICRO MIST Nebulizer...
PulmoMate nebulizer will not create mist
Make sure your unit is clean and you have a clean filter. Tighten all of the connections. make sure your medication is mixed properly as well.
Apr 20, 2010 | DeVilbiss PulmoMate Aerosol...
Routine cleaning Mabis XP.
If your unit is the one pictured, he cup with the medication can be taken apart to be cleaned... the top unscrews and the nebulizer comes out....and should be done so after every use. Do not use house hold chemicals to clean the unit. Use a water/distilled vinegar mixture to clean, then rinse with clean water.
Apr 07, 2009 | Mabis Neb Xp Portable Handheld Cmpressor...
My solution in the nebulizer is not foaming or misting!
you may need to switch out your mask unit, the cup the medication is put into has a very tiny hole for air to circulate through. if that hole has been tampered with, or is partially clogged you will not get a mist. you should change out your mask and tubing regularily for sanitary reasons.
hope you get it running again!
Mar 20, 2009 | DeVilbiss PulmoMate Aerosol...
Hudson Rci T UPDRAFT II NEB MOUTHPIECE TUBE HUD1732 - T UPDRAFT II NEB MOUTHPIECE TUB Logo
293 people viewed this question
Top Hudson Rci Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Hudson Rci Health and Beauty Expert? Answer questions, earn points and help others
