Question about Fuji Finepix Z20fd Digital Camera
Fujifilm FinePix Z20fd protected card??
I downloaded my pics to my computer, by putting the memory card into the harddrive. and when i went to put the memory card back into my camera. and it worked just fine. till i turned it on and tryed to take a pic. it said "protected card!" on the screed,.
HELP!
  • julest Feb 23, 2009
    my card keeps coming up as protected card. I used it in a digital photo frame and when i put it back into my camera it wouldn't take any more pictures.
  • Anonymous Mar 01, 2009
    I had exactly the same problem, i couldnt delete anything, it flashed protected card, thanks for the solution it was so simple!
  • 16 Answers
The memory card should have a little switch on it, try it in the other position. It is a safety lock to stop it getting wiped.
Posted on Feb 13, 2009
  • lynz_6_8 Oct 07, 2010
    thank you so much been doing my head in for ages x
I love you mr man :)
Posted on Feb 05, 2010
No view from screen or viewfinder
Hi, have you tried another memory card in case the other one is faulty ,if the original card is ok then you will have to put into a fuji repairer to inspect. If you are still under guarantee the contact fujifilm.
Dec 17, 2015 | Fuji FinePix S5700 Digital Camera
Turn off protected mode
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 10, 2012 | FUJIFILM FinePix JX310 14.1 MP Digital...
My camera is saying protected card and won't work now. I put the card into my computer to download some pics and now it wont allow the camera to operate
Take the card out of the camera, there should be a small slide switch on the memory card, just slide it over and that should release the lock giving you access to the pictures. The manufacture put it there so you would not delete by mistake.
Jan 21, 2011 | Fuji Finepix Z20fd Digital Camera
I downloaded pic from my fuji camera on my pc and now my camera says "protected card" what can i do
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 24, 2010 | Fuji Finepix Z20fd Digital Camera
I have a Fiji Finepix Z20fd camera, and have approx 350 photos on the memory. Yesterday the message "memory full" appeared when i tried to take a photo so naturally i attempted to delete a some to make...
Having pics on both the internal memory and a memory card is asking for trouble. Take out the card and download the internal memory to your computer. Then, go into the menu and find "format" and erase the internal memory. Then, download all the pics from the memory card using a separate card reader. Then, insert the card into the camera and do the format thing again to erase and optimize the card. Now you have a fresh start...never use the internal memory again.
May 03, 2010 | Fuji Finepix Z20fd Digital Camera
I have a finepix s5500 camera but the softwear is xp and i need a vista version, is it possible.
All Fujifilm digital cameras will work on Windows Vista using drivers already installed on the operating system.
The finepix viewer software supplied with our cameras will require a update which can be downloaded from the following link
http://www.fujifilm.com/products/digital/download/02/index.html#windows5.3
Accessories
The following products are not compatible with Windows Vista:
FD-A1/FD-A2 (Floppy Disc Adapter)
DM-R1 (Image Memory Card Reader)
DPC-R1 (Image Memory Card Reader)
The following products are compatible with Windows Vista:
SM-R1/SM-R2 (Image Memory Card Reader)
PC-AD3 (PC Card Adapter)
DPC-AD (PC Card Adapter)
DPC-CF (CF Card Adapter)
DPC-UD (USB Pen Drive)
Oct 17, 2009 | Fuji Finepix Z20fd Digital Camera
I bought a fujifilm finepix Z20fd camera with no cd to install
You don't need to install your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 13, 2009 | Fuji Finepix Z20fd Digital Camera
Everytime i plug my camera in, an i/o error occurs. i have a fujifilm finepix z20fd
Try NOT connecting your camera to your computer.
Jul 29, 2009 | Fuji Finepix Z20fd Digital Camera
Can't copy pic from camera to memory card :(
I needed to be actually looking at my photos then go into the menu then its pretty straight forward.. asks if you want to save from the camera to the memory or vice versa..
Mar 25, 2009 | Fuji FinePix Z100fd Digital Camera
I got a pink Fujifilm Finepix Z20fd and pictures won't download
You don't have to use the software that came with the Fujifilm. I have the same camera. If you're on a laptop that has a slot for SD cards, (if you have an SD card) you can just put your card straight into your computer and load the pictures that way. Also, if you have an SD card reader, you can use that. And if you're on a desktop without either of those options; once you plug your camera into your computer, go to your start menu and click 'My Computer,' then your camera should come up as a removable disk device in the folder. From there, you can drag and drop the pictures onto your desktop or your My Pictures folder.
Jan 07, 2009 | Fuji Finepix Z20fd Digital Camera
Fuji Finepix Z20fd Digital Camera Logo
1,458 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
