Question about MSI KM4M-V SOCKET-A WITH VIA KM400 CHIPSET (KM4MV7061020) Motherboard
Memory upgrade I have a KM4M motherboard. I can't tell whether it's a LM4M-L or V or whatever just KM4M. I currently have one 512MB memory module in use. It is marked DDR333 64X64 on a paper label. I would like to upgrade to 2GB (1GB module in each slot). I see lots of discussion on low/high density. I don't understand it fully. Am I limited to using certain memory modules/manufacturers on this system? Thank you.
    Genius:
  • MSI Master
  • 1,102 Answers
Yes you are
take your information to your pc shop and explain what you want to do.
They will then direct you in what type of memory and how much memory your system can take.
( A smaller pc repair shop will give you better advice and a better price then a major shop.)
Please don't forget to rate me
Posted on Feb 13, 2009
I have a dell optiplex G240.its ram is 256 and 512mb.but now 512mb ram doesnt support.what can i do?
Well, there are many different types of Ram (Memory) available for many different motherboards. Your current computer support a maximum of 1Gb of ram. And judging from the date it was released, your motherboard seems as though it only supports DDR Ram. Therefore you may either have to buy another set of ram or buy another computer (used if possible). Although the second option is only valid if you are looking for something that is faster than what you currently have. Personally speaking upgrading the memory for an old build will not give you the best performance out there.
List of Memory Type
Ranging from Slow to fast
DDR Memory
DDR2 Memory
DDR3 Memory
DDR4 Memory
Other Thought's
Re-seating your Ram(Memory) may help get your 512MB
ram running again, however if your 512MB ram is a faulty module it may fail to work.
Aug 07, 2015 | Dell Computers & Internet
Is there any specific memory card brand and value for ASUS P4V533-MX? I want to upgrade my computer's RAM from 256MB to 1Ghz, I bought two DDR1 512MB surplus memory cards with different brand name, neither...
This mother board Support only DDR333 PC133 SDRAMS. Check the lebel of your newly bought memory modules whether it matches or not. If not then you should replace them.
Mar 15, 2011 | ASUS P4S533-MX Motherboard
I have intel d845gvs1 motherboard with P4 2.4 ghz, Currently have 2 ram (512mb & 256 mb) how much further can i upgrade the ram, 1GB or 2GB also is the current combination of ram is right?
"Supports up to 2 GB of system memory with DIMMs utilizing 512 Mbit
technology DRAM devices"-intel
you can use 2 sticks of 1 gig apiece to get to 2 gigs of total memory, but you have to make sure that the ram sticks use "512Mbit " technology.
the 512Mbit technology refers to the arrangement of memory chips on the ram cards. a card which uses 64Mx8 (8 seperate memory chips of 64M apiece) would be appropriate.
"Nearly all motherboards only recognize 1 GB modules if they are low density 64M×8 modules. If high density 128M×4 1 GB modules are used, they most likely will not work."-wikipedia"
Oct 27, 2010 | Intel D845GVSR Motherboard
Upgrade ram
In order to upgrade the ram of your desktop. First you have to check the ram specifications. If wrong specifications the desktop will not work. To check you have to remove the ram from your desktop by removing the screws behind your desktop. Open the lid and you will see the contents of your desktop. Besides of your processor, there is ram installed. Unclip it. Then bring that ram to the computer shops. Purchase a ram higher than the ram installed in your desktop. Afterwards, install the new ram to your desktop. Good luck.
Sep 13, 2010 | Acer Aspire T690 (AST690UP820A) PC...
I have a MSI KM4M-L motherboard and it will not accept any other memory than the 512mb strip that is in at the moment, and this it reads as a different size. It has a Duron 850 processor.
Usually this is a BIOS problem.
Go to the MSI website and make sure you got the latest BIOS for the board, and upgrade it if you need too.
While there, download the operating manual (usually a PDF file) and look where it tells you what kind of memory is compatible with it.
You might have to put memory in slots in a certain order.
I.E. Memory in slots 0 and 2 first.
And, or, in particular on older boards the memory might have to be the same size sticks, etc.
Jul 15, 2010 | MSI G31M3-L V2 Motherboard
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
My problem that i can uprade my SDRAM 128 to 512
You can use PC-100 memory up to 512MB max (2X256MB)
Apr 12, 2009 | Dell Optiplex GX110 (2909T) Motherboard
Memory Problems (MSI KM4M-V Motherboard)
if you know the make and model number of the memory sticks you will need to contact the manufacturer to find the voltage specifications so you can adjust the bios accordingly. Or do a google search with the model number and make of the memory stick for voltage details
Jan 14, 2009 | MSI KM4M-L Motherboard
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
KM4M-L and graphics cards/memory queries
I would hate to burst the bubble but if you buy any DDR2 memory, then you will be wasting your money.
This motherboard only supports standard DDR upto 333mhz and only 2gig max of that.
Video card wise, then an ATI 9800 Pro can be had cheaply or an nVidia 6800 AGP version can be purchased new.
Hope it helps =)
Apr 12, 2008 | MSI KM4M-L Motherboard
Computers & Internet Logo
52 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
