Question about IBM ThinkCentre A50p PC Desktop
Extra cd drive has come after operating system installation which does not exist only. my computer is showing as DVD-RAM drive and CD Drive. Earlier it was just DVD-RAM. kindly help me resolve it. kindly mail me on to shashijayan@gmail.com
    Genius:
  • 1,226 Answers
Please try go to control panel and then administrative tools, computer management. click drive management then delete the excess drive which is unknown to you.
else if this not resolve you can maybe its a network drive. If you are sure that this not annoy to you then you can ignore, However if is bad to you then you can eliminate that by clean format and re installation of windows again.
may this help,
melnavz
Posted on Feb 13, 2009
In my desktop computer the LG CD/DVD writer/reader is showing empty though the CD is filled with data..hat could be the reason, i tried by re-installing the drivers but no success...
Not knowing the operating system, In windows 7 and 8 sometimes it forgets the cd format. Then you need to go to the device manager and remove the drive and let windows re-detect it.
Feb 11, 2015 | LG Super Speed USB 20X DVD / 48X CD...
Missing Matshita DVD-RAM UJ880AS
Go into my computer, if DVD driver is shown it will run the DVD-RAM driver," may mean the unit must be replaced". If on the other hand it is missing the driver, it will need to be re-installed, or you can try a systems restore to bring the computer back to an earlier time before this became a issue.
Apr 28, 2012 | Toshiba Computers & Internet
Dvd/cd ram not opening cd
You can try to delete upper and lower filters for your system. go to start>run>type in regedit click ok> start looking for this parth HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318},when click on the folder look on the right column and look for upper/lower filters and delete it. restart system. Try updating the firmware of the optical drive depending on the model. if you want to chekc the model of your drive go to device manager right click my computer>select manage>select device manager then lookf or cd /dvd .
caution:be careful with deleting registry for your system this might affect your operating system functionality.
Jun 25, 2010 | Dell (0F146) Internal DVD Drive
My disc drive wont let me burn movies on dvd+rw or dvd-r and It did before atleast with the dvd+rw, what could be the reason?
Summary:
1) Press eject button on case, on drive, button on keyboard (if exists).
2) Right-click drive icon in Windows and select Eject.
3) Turn off PC and inert a straightened paper clip into the manual release hole on the drive.
4) Check the power cord on the back of the drive.
MS FIXit, Resetting Upper and lower Filters (XP, Vista and 7)
First... try to use the MS Fixit (for Vista) if you are on the computer having the problem)...
c01733077.jpg Microsoft Fix it Solution
Otherwise, here are the manual steps (overview):
1) Uninstall the CD/DVD drive in Device Manager and DO NOT RESTART the computer.
2) Uninstall your CD burning software (make sure you have the installation disc or you can resinstall from Start, Programs, PC Help and Tools, Recovery Manager (or Driver/Application Recovery). If you don't have the installation discs, skip this step - it might still work).
3) Open the registry editor (Start -> Run -> enter Regedit) ... might want to make a backup of the registry at this point.
4) Open the following keys:
+ HKEY_LOCAL_MACHINE
+ SYSTEM
+ CurrentControlSet (or the current control set with lowest number if that is all that is listed)
+ Control
+ Class
5) Select 4D36E965-E325-11CE-BFC1-08002BE10318. It has to be this exact key - make sure you can see the last numbers!!!
6) Delete the UpperFilter and or the LowerFilters value in the right window if either exists.
7) RESTART the computer - this step is important. Wait for Windows to find and install the CD/DVD drive you removed earlier.
8) Reinstall your burning software and restart the computer again.
c00877299.jpg v
Jun 07, 2010 | Computers & Internet
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Acer dvd driver missing acer ferrari 400 dvd uj-845-c
CD/DVD drive drivers are Operating System generic drivers and need not to be installed explicitly. The CD/DVD drive drivers are installed along with the Operating System and can be reinstalled automatically at next restart, if missing.
Check in the Device Manager under the "CD/DVD drive" category if there is any device listed there and having exclamation mark. If there is any exclamation mark visible beside the CD/DVD drive name then right click on it and restart the Computer.
Restarting the Computer will reinstall the CD/DVD drive driver thus causing it to work normally.
Nov 25, 2009 | Acer Ferrari 4005WLMi Notebook
My computer showing an extra cd drive which does not exist after installation of operating system. how do i remove that kindly reply on to shashijayan@gmail.com thanks
You can remove by going to the device manager. this is located by right cliking on the my computer icon on the start menu. then, slide down to properties then, click. once you click on properties, you will see the system properties window. click on the hardware tab. then click on device manager. you can pick out the extra drive here and remove it from your system.
Feb 13, 2009 | LG GMA-4020B Super-Multi...
Windows will not start
Ok ...that message about the PXE is showing up because the computer cant find an operating system on the hard drive for some reason.
Try booting from your Vista DVD ,let setup start then running Start Up repair ....
3. If prompted, press any key to start Windows from the installation disc.
NoteIf your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computers BIOS boot order
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Jan 02, 2009 | Microsoft Windows XP Professional
Hp invent p dvd940i does not see dvd disk
1. check your system meets the requirements for your device:
• Minimum system requirements: 800 MHz Intel® Pentium® III
processor or equivalent, 1.6 GHz Intel® Pentium® IV processor or
equivalent recommended (Actual drive performance depends on PC
configuration)
• 128 MB RAM (256 MB RAM recommended for video editing)
• 1024 x 768 video resolution with a minimum of 16-bit color required
for DVD authoring and editing
• Video capture: IEEE 1394 interface or analog video capture device
required
• Minimum hard disk space requirements: 1 GB free for included
software installation, 10 GB free for DVD video disc creation (18 GB
free for double layer). Internet connectivity recommended for software
updates
• Operating system compatibility: Microsoft Windows XP/2000
Professional SP4, Windows XP Professional x64 edition, and
Windows Server 2003
2. Have you install the sowftware that came with your device?
3. is your system recognizing the hard drive (go to start>run>type devmgmt.msc and press enter> and look under cd/dvd rom drives... is your device listed? is it showing with a ? unknown device or a ! next to it's name?
a. if the device is not listed chances are you didn't set up the jumper correcly when installing the device or the device may not be powered or there's an issue with the data cable connectd to the device and the motherboard, check your physical setup.
4. check the removable media is in fact compatible with your drive: this is the compatibility list
• Device write media compatibility: CD-R, CD-RW, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, LightScribe CD-R,
LightScribe DVD+R, LightScribe DVD-R, 4.7 GB single-sided/9.4 GB
double-sided DVD-RAM (2.6 GB single-sided/5.2 GB double-sided
media not supported)
• Device read media compatibility: DVD-ROM, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-Video, 4.7 GB
single-sided/9.4 GB double-sided DVD-RAM (2.6 GB
single-sided/5.2 GB double-sided media not supported), CD-R,
CD-RW, CD-DA, CD Extra, CD-ROM (Mode 1 - Yellow Book),
CD-ROM/XA & CD-I Ready (Mode 2/Form 2 – Green Book),
Photo-CD (single and multi-session), VCD, CD-Text
data taken from http://h20426.www2.hp.com/product/opticaldevices/sg/en/pdf/dvd940i_dataSheet.pdf
Sep 28, 2008 | HP Computers & Internet
IBM ThinkCentre A50p PC Desktop Logo
65 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
