Question about Blodgett Kitchen Ranges
Error code F3 on Whirlpool RF360BXEN range
Won't bake or broil, error code F3 comes on
    President:
  • 1,902 Answers
F3 stands for a faulty oven sensor. Unplug the oven, then replace the sensor. Should be back to normal. The sensor is inside the oven. When you pull on the sensor, you'll get to a male/female quick connector. When you unplug it, be careful not to lose the other end behind the oven wall or this simple repair won't be so simple anymore.
- Replacement sensor for your oven
If this helped please rate. Thank you
Posted on Feb 13, 2009
    Sergeant:
    Champion:
  • 338 Answers
Replace your temperature sensor. if that does not work replace the control. i doubt you have an electric meter to take an ohn reading.
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool mod# rf365pxmt top broiler comes on .
This is usually a oven too hot error code. It may be the oven sensor going bad. The control relay stuck. try shuting the power off and resetting it and see if it comes back.
Oct 06, 2014 | Kitchen Ranges
Ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 20, 2012 | GE Stove / Oven / RanMain Glass Top Assy....
I had the E2 F3 code while I was baking something. Is it safe to eat the food that was in the oven at the time the error occurred?
F3
- E2 Oven temperature is too high (Cook
mode)
Replace
Oven temperature sensor (RTD)
Note: Applies to all
F3-E... codes.
Dec 21, 2010 | Whirlpool GR460 Electric Kitchen Range
Sears (Kenmore) drop-in unit, Model 911.4698815. Ran the self-cleaning cycle - now it's showing Error Code F3 and neither the bake element nor the broil element will work. Any help would be...
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Sep 12, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Oven keeps kicking off and the display comes up E2 F3. What does this mean?
error code for Bake Range Over Temperature, You may have a bad oven sensor, located inside oven at back left, or a bad board, Probably your sensor
Aug 28, 2010 | Whirlpool GY396 Electric Kitchen Range
Oven throws a E0 F3 error code
Most likely the temperature probe. My fan continued to run until I disconnected my temperature probe. Unscrew the 2 screws holding the probe in place and pull on it until the plastic connector male/female comes through the hole in the back of the oven. Disconnect the connector being careful not to let the female fitting slip back into the hole. Once I disconnected the temperature probe the fan stopped running. I believe a new temp probe/sensor will correct the F3 E0 error and correct my Bake function. The oven wouldn't preheat or turn on. The Broil and Clean functions worked but not the Bake function.
Jul 13, 2008 | Whirlpool Kitchen Ranges
Broil element will not work
You need to check the oven sensor. It should be about 11k ohms. This is the metal rod in the back top of oven cavity. Access it from the rear. UNPLUG POWER FIRST!!
Nov 03, 2007 | Kitchen Ranges
Kitchen Ranges Logo
153 people viewed this question
Top Blodgett Kitchen Ranges Experts
gbob59
Gil Shultz
ray gallant
Are you a Blodgett Kitchen Range Expert? Answer questions, earn points and help others
