Question about Sony KP-51HW40 51" Rear Projection Television
Removing the speaker grill from my Sony KP-53HS10
I'm trying to fix the red line problem on my Sony KP-53HS10 rear projector but I'm having difficulty removing the speaker grill thus allowing me access to the necessary component. Please help.
    Novelist:
  • 184 Answers
There are two screws (1/4 in. philips) located in the lower left and right front of the cabinet near the floor. They may be concealed by a plastic overlay. It can be popped off with a small screwdriver.
Be careful!
michtech
Posted on Feb 13, 2009
Red horizontal slightly curved lines on dark scenes. Sony KIP-57WS500 Rear Projection TV 57".
u need to adjust the focus screen , this is located right under the picture tube , u need to take the front speaker grill off , look close to the botton of this grill and u would see a small cover that is covering the screw , remove ths screw and pull hard
Dec 14, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Red lines on screen
try adjusting the screen voltage for the red tube the adjustment is located behind the speaker grill on the focus /screen adjustment block
Feb 05, 2010 | Sony KP-57WV600 57" Rear Projection...
Remove Speaker Grille from Sony KP-65WV700
So you got the six screws undone, great! Now you can pop off the front speaker grill. The easiest way is to work your hand along the top and bottom to pop the plastic out of the "holders"
If what you are describing to me is the main wires still attached to the rest of the TV. So don't pull it out too far! If you do it right you won't have to unplug the wires, and save yourself some hassle... with this TV you'll have to pull it out JUST ENOUGH to get access to the carboard/masonite backing, removing such will give you full access to the six controls.
Adjust from there! Sorry for the wait, and I hope this helped out!
May 30, 2009 | Sony KP-51HW40 51" Rear Projection...
Color is off in Sony KP-53HS10 Rear Projector TV
http://office.manualsonline.com/manuals/mfg/sony/kp-61hs10.html
May 15, 2009 | Sony KP-53HS10 TV
There are no screws on the speaker grill of this particular model
If it is KP-51HW40 Sony TV
Speaker grill has 2 caps covering 2 screws at bottom of speaker grill.
Below is an image showing caps of speaker grill that might help you to open it.
Feb 13, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen Is Blurred
Did you try hitting the small button on the front of the tv labled flash focus? Try pushing this button because this model only features auto focus for aligning the red/green/blue projectors.
Nov 24, 2008 | Sony KP-53HS10 TV
Sony KP-53HS10 lines flicker across screen
tap around on the circuit boards in the rear of the television. narrowed it down to the Comb Filter circuit board. It is the smallest upright circuit board behind where you plug in all your connectors. pulled it out cleaned it off, reinserted it
Jan 23, 2008 | Sony KP-53HS10 TV
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
KP-57WS500
Sounds like a conergence circuit failure, probably a couple of AMPs and a few discreet components. Probably 250-300 repair
Apr 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
215 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
