After wask cycle the unit will not go int any other modes because drum will not spin, I can spin it buy hand when cover is open.
This is a direct drive motor so spinning it by hand says that the bearing is not seizing up so it could be a control or maybe a rps sensor . remove the screws from the back of the control panel and you will see the tech sheet . the sheet will list a number of different models so just follow the GWL15 instructions . you will then be able to see were the fault is and you will be able to activate all components one at a time .
SOURCE: Washer spins but not enough to extract water from clothes or tub.
could be a loss belt or a kinked hose, since you say it feels weak i would think it is not getting up to speed which would be a loss belt or drive train issue, of course it could just be to big a load or on slow spin speed setting
SOURCE: not spinning
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
It spins only with the lid closed
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: drum does not spin
We have an LG TROMM with the same problem, 3 years old as well. We bought the extended warranty (Huge waste of $$$$). So far they have determined it is not the motor or either of the control boards. We think it might be a relay switch or possibly the brake. Good luck with yours, we just went out and bought a new washer.
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
SOURCE: loose drum bangs during spin cycle turn by hand
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
