Question about GE DCSR483EA Electric Dryer
Not drying adequately
How many elements are in this dryer--model 86983810? It still will dry, but only half a load for an allotted period of time. We have vacuumed it out, but that doesn't seem to help much.
    President:
  • 1,902 Answers
There are only one element in the system. if your system is not drying the clothes properly then you should really check the temp sensor to make sure that the system is working correctly and not shutting off at the wrong time or to early and not really heating up properly
Posted on Feb 13, 2009
Takes too long to dry
Using the proper venting and making sure the vent pipe is the proper length is very important to the operation of the dryer.
It is recommended to use of solid metal vent pipe, 4" in diameter, for adequate operation.
Check for an obstruction in the ducting. Make sure the outside wall damper is operating easily. If flexible ducting is used, be sure that it is not kinked and is installed properly. It is recommended that you clean the duct work completely at least once a year.
  • Remove and clean the lint filter each time it is used. The filter can be washed with warm soapy water to remove fabric softener residue from the screen.
  • There may be too many items in the dryer. Only dry one washer load at a time. Do not combine washer loads to make one large dryer load.
    A dryer whose heating element is partially or completely burned out will definitely prolong a dryer's drying time. Open up your dryer's cabinet and locate its heating element. Test the element, and if it is no longer functioning as it should, you will have to replace it.
    It is less likely, but it is possible that your clothes are taking so long to dry because of a faulty thermostat. Open up you dryer and test each of your dryer's thermostats. If any are not functioning properly, they will have to be replaced.
    Jan 04, 2015 | Dryers
    Heating element not putting out much heat and periodically pops the internal breaker. When it is working, it takes 3 times the normal amount of time to dry a load.
    restricted air flow, disconnect vent tube dry a load of clothes. You can use a leaf blower or a shop vacuum to blow out vent tube, Tim
    May 29, 2011 | Fisher and Paykel DEGX2 Dryer
    Dryer not drying in alloted time
    there is a thermostat. it usually is located on the heating element housing
    May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Does not have adequate heat. It does have some heat
    if dryer is heating but not drying there are two things to look for. check for air flow outside. blocked air flow will cause your drying time to be really long. the other is you may have an element that is shorted to ground. when this happens your unit is heating off half your voltage. this is something that can be detected with an ohm meter or the naked eye. unplug first.
    Mar 03, 2010 | Roper RES7646KQ Electric Dryer
    I have a front loading frigidaire dryer that is taking 3 - 75 minute cycles to dry one load... what could this problem be?
    Confirm if the problem is just in timed dry or auto a swell. Since you say timed, you likely have either blockage in the lint trap, or exhaust or an element which is functioning at half power, half burned out
    Sep 06, 2009 | Dryers
    I have model # eed4300tq0 it takes 3 times longer to dry than it use to. it use to dry in one cycle on high heat,now i have to use high heat 3 times to get completely dry. dryer is only 1 and a half years...
    Blocked vent hose . Disconnect the hose from the dryer and dry a load . If dryes ok , check the vent hose and vent . Make sure there is good air blowing out the back .
    Aug 08, 2009 | Estate TGDS840JQ Gas Dryer
    Dryer taking too long to dry clothes
    Hello :)
    Very common problem. You need to call a
    duct cleaning company and tell them to clean
    your dryer vent. Rule-of-thumb: dryer vents
    should be cleaned every couple of years to
    prevent them from being clogged with lint and
    causing lint fires. This is definitely your problem.
    Good luck :)
    p.s. one way to verify a clogged vent is
    to go outside where the vent exits the house
    and feel the air-flow. should have adequate air-flow.
    Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
    Amana dry wont dry
    partially bad heat element. some models have a double element maybe half of it is burned out
    Nov 17, 2008 | Amana NDE2335AY Electric Dryer
    DRY TIME IS VERY EXCESSIVE
    Excessive drying time can be caused by a number of things.
    Is the vent clear of obstructions? If not then the vent and ducting will have to be cleaned. This ch be checked by removing the vent hos from the back of the machine and testing the dry time with a small load of a couple of towels.
    Is the temperature hot inside of the dryer? If not then the heating element may have a problem.
    Is the washer spinning most of the water out of the clothes? If not then the dryer is overworking to remove the water.
    Is the dryer fairly old or was it a "scratch and dent" floor model? Then there may not be an adequate seal around the dryer drum and a lot of drying potential is lost.
    Is there lint build up in the blower or is the blower not spinning? This cause the air to not circulate. It can be checked by removing the rear duct hose and running the machine.
    Jul 28, 2008 | Maytag Dryers
    Why wont my machine start drying?
    I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
    Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
    GE DCSR483EA Electric Dryer Logo
    Top GE Dryers Experts
    John Tripp
    John Tripp
    gbob59
    Are you a GE Dryer Expert? Answer questions, earn points and help others
