Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
Sony KF 42WE610 blinking red (non-lamp light) won't turn on
I have a Sony Grand Wega that won't turn on. It blinks red for a minute or so in intervals of 3 and then stops. The night before this happened the screen was very dim but the lamp light is not coming on like it did last timethe bulb went out and the bulb appears to be OK. It doesn't look damaged and is less than a year old. Wondering if I should buy a new lamp anyway. Any ideas???
  • 7 more comments
  • amymoody Feb 13, 2009
    Not thinking it's a power supply issue- Can somebody else provide their 2 cents. Thanks.
    Now that makes sense- How do I remove the part that needs to be fixed and where might I take it??
    Is it worth fixing?
    Will getting a new lamp be a short term solution?
    how do you check the soldering
    3 1/2 yrs old
    too old
    Dipu007- you're a genius. I pressed the cover in tighter and it began to flash green (instead of the 3 flash red your cover is not on right light) and then the lamp light came on. At least now I know to buy a new lamp. Thanks.
  • Anonymous Mar 19, 2014
    Replaced lamp with Sony part. Screen is still dim. It is 7 years old. Any ideas?
  • 3,037 Answers
Hello
Three blinks
- B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Let me know what you find after checking these. The power supply is at fault as others have suggested, this is just a little more detailed.
bestdarngood
Posted on Feb 13, 2009
    President:
  • 2,110 Answers
Lamp Cover is not attached properly.
Please remove lamp cover and make sure to fix it properly, well seated in its place and tight screw. There is a safety switch under lamp cover that should be pressed when lamp cover is closed.
if it could not solve ur problem ..then u have to change LAMP..
  • 547 Answers
If it's under new warrenty don't take it apart use the warrenty
    Master:
  • 505 Answers
If the TV is less than a year old, contact Sony. They will have engineer send at your home to diagnose the problem and repair it for you.
Thanks
  • Indrajit Roy
    Indrajit Roy Feb 13, 2009
    Here are a couple to get you started...
    http://forum.ecoustics.com/bbs/messages/...
    I've never experienced this problem myself - knock on wood - but from what I've read, it can be caused by a couple of different things.
    One problem involves the lamp cage being loose. The fix is easy. All you do is remove the lamp and put it back in, making sure everything is tight. I guess they had a problem at the factory, for a while, not tightening the lamp cage. After a certain number of heating cycles, the lamp quits making connection. These were made mostly from late 2003 to early 2004, as I understand it.
    The other problem is more serious. Sony has an advisory out about it. I guess they have to replace like 9 different parts - boards and so forth.
    Anyway, good luck! Hope this helps...
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem may be the circuit
board.There may be some problem in your chips.
It might not have been properly soldered.so check
for the soldering.This could be the only reason.If you
still continue the problem check the transistor once.
These two could be the reason for the failure.
check this out..
thank u..
  • Hariharanath V Feb 13, 2009
    hi..First try this out.Look whether the
    soldering is done properly in the main
    board.This may solve your problem.
    check it out..
    thanks..
    hi..that you cannot be checked.It needs a electronic
    expert to attend to the problem.
    thanks..
    President:
  • 1,902 Answers
If you google search this system you will see that ALOT of people just like you are having the same problem and you either continue to replace the lamp or just buy a new TV altogether. Sony is trying to figure out why this system is doing this since for the most part all there TVs are really good systems
  • 296 Answers
Power supply failure.
  • 6,784 Answers
That code represents a power supply board failure. probably a solder break or, circuitry separation.
  • 3 more comments
  • Michael Masters
    Michael Masters Feb 13, 2009
    This can be removed and transferred to a local tech for a rebuild. about $120 tops.
  • Michael Masters
    Yes, its worth it. you have a good brand.
  • Michael Masters
    If your tv will not power up, its not the lamp, its the power supply board.
  • Michael Masters
    I do way more power supply replacements than any other replacements in the last three years. they take a beating.
  • Michael Masters
    you will have to remove the power supply board itself to check the solder circuit points.
Sony 42" won't turn on
TWO things to look at---inspect the lamp this model should use for brightness. Look to see what lights on front of set are on or BLINKING.
Jun 08, 2012 | Sony Grand Wega Kf-42we610 42-inch...
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
My sOny tv KF-42WE610.. Won't turn on.. I just
Please let me know how many times it will blink to determine where the exact fault came from.
Jdvillanueva
Jun 17, 2011 | Sony Televison & Video
Sony tv kf-42we610 tv will not come on and red light blinks three times
Three flashes usually means the lamp cover is not attached securely and the TV has gone into a "stand by" mode, recheck that the lamp,lamp door, and front panel is securely attached.
Good Luck !
Feb 07, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Sony Grand Wega KF-42WE610. When turned
there is a 12v cable to main board it prob has a dry joint
Oct 31, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
I have a sony grand wega model kf-42we610 I will be watching tv and it will turn off on it's own and then come back on 30-60 seconds later. If I turn it off the light under the power button will blink 5...
Check your lamp cover on the rear it may be loose which will cause the tv to turn off. Also the light under the power light is the lamp indicator. If it is blinking it may be getting ready to fail.
Jan 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Hi there
Yes the lamp light means change the lamp. If you have not changed one in this tv yet it is overdue.
Jul 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
1,004 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
