Question about OKI C5800Ldn Led Printer
OKi C5800ldn 231: fatal error 03
Fatal error code
231:fatal error 03 (as noted on display)
what does this mean and can it be cleared without service call. budget super tight and trying to pay someone to fix it if remote assistance and information can be gathered.
thank you!
  • Anonymous May 03, 2009
    Have tried several times since getting this message. Provided no solution to this error message. Pulled out standby injet printer and using it. Man, I miss my double sided color laser printer!
  • EOLA Nov 09, 2009
    Just got "FATAL ERROR 03" on a OKI c5600.
    the fault was that on the upper left corner of the toner there is a small plastic door, and inside of that a small chip of some kind.
    My problem was that the plastic door had gone missing and the chip hade fallen out, not completley, it was haning on the edge.
    So my guess to all you that get this error is that you machine looses contact with this chip.. it's one in every toner.
    Cheers
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Posted on Jul 27, 2010
Switch off printer. Unplug power source from printer. Re-plug same and power up again. Should work Have same problem with OKI 5900
regards
Liam
Posted on Mar 22, 2009
Same problem with OKI C5950. Shut down power and plug on power again is my solution. Problem appears first with using refill toner not the original one.
Posted on Jun 19, 2009
Happens with refilled cartridges. You MUST insert the new chip that comes with the refill. If you get the error message after doing so remove the new chip, rotate it 180 degrees and reinsert it into the cartridge. Solved the problem for me!
Posted on Nov 18, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 131 Answers
Just had this in work was a paper jam from tray 1
Posted on Feb 26, 2015
Just remove the chip - worked for me!
Posted on Mar 27, 2014
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Fatal Error 121
Hi and welcome to Fixya!
"Fatal Error" on your printer display or status monitor simply means a problem has occurred requiring action to clear. Fatal Error explanations are not usually found in the manual. You can check the list of error codes from the link below:
http://www.c8600.co.uk/index.asp?printername=C8600&menumode=0&content=errorcodes
RECOMMENDED STEPS:
First, try turning off your printer then turning it back on. If you're still getting the same error message, make sure the printer is plugged directly into the wall. Often, the issue is power-related.
If the problem persists, write down the message including the 3-digit error code number and send an email to "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers scrolling across the display after the 3-digit error code, write it down and report them when calling or emailing Customer Support.
Jun 29, 2011 | OKI C5800Ldn Led Printer
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 25, 2011 | OKI C5200n Laser Printer
What does error code f67 on a siemens wash machine mean?
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
Apr 18, 2011 | Bosch Washing Machines
Fatal error 708
Dec 14, 2010 | OKI C3530N Color MFP Printer
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
May 08, 2010 | OKI C9600hdn Laser Printer
Konica Minolta Magicolor5440DL Error Code
error 0094h = 2nd image transfer pressure/retraction failure
basically it means that either a sensor or cable is not fitted supposedly and reseating could possibly solve the issue.
you can research the error code in the following service manual:
http://printer.konicaminolta.com/drivers/other/Manuals/5400/smfs_54.pdf
Mar 09, 2010 | Konica Minolta magicolor 5440 DL Laser...
Konica 3135 Copier
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Feb 25, 2009 | Office Equipment & Supplies
OKI C5800Ldn Led Printer Logo
41,721 people viewed this question
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
