Question about Magellan Maestro 4040 GPS Receiver
Touch screen will not work.
Whenever I touch the screen it will not change. I cannot get it to go to the next program or menu.
  • Anonymous Feb 17, 2009
    Touch screen is not working on mine also.
Mine is working now after i reset the thing. Good luck
Posted on Feb 16, 2009
How do enable my touchscreen?
This is one link that shows how in pdf (however if you provide your exact model and operating system, you can get a clearer answer) https://www.lenovo.com/shop/americas/content/user_guides/a720_ug_en.pdf
touch screen starts on page 12
2.1 Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Windows 7, Select "Start" - "Control Panel". 2. In Control Panel, select "Hardware and Sound". 3. In "Hardware and Sound" window, select "Tablet PC Settings". 4. In "Tablet PC Settings" dialogue, click "Calibrate" button. 2.2 User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor.
Nov 24, 2015 | Lenovo Computers & Internet
Touch problem
Nokia designed the N97 with a touch-screen calibration program to remedy problems with the touch screen. Opening the touch-screen calibration program requires you to use the touch screen, which can prove difficult. You're forced to judge where to tap the screen because the screen isn't recording the precise location of your taps. To find the touch-screen calibration program, open the main menu, select "Settings" and then "Touch Input." The program provides on-screen instructions to help you finish calibrating the screen.
Oct 23, 2012 | Nokia N97 Cell Phone
My touch screen froze, so I did a soft reset. This didn't work. So I did a hard reset. All seemed to be going to plan until the 'Align screen' appears. I align the screen as instructed but instead of going...
Whenever you do the alignment touch the spot on the screen with the stylus and hold the stylus on the mark until it moves to the next corner.... this may work
Nov 28, 2009 | HTC Touch HD Smartphone
How do i set up speed dial on my DP80F fax machine and erase the old ones?
1. Display the TEL LIST ENTRY Menu by Pressing 'Menu' and scrolling down to 3. Group Numbers
2. Then Press '2' or scroll down to 'One Touch Keys'
3. Press the desired One Touch Key that you wish to program.
4. If the One Touch Key has not been programmed, follow the prompts on the screen and enter the desired information, pressing the 'Enter' key after each entry to move to the next field.
If it is already programmed the display will say "Already Assigned". Wait 2 seconds until it says "One Touch NBR" then select '1' to delete, '2' to modify or '3' to retain. If deleting confirm delete by pressing the enter key. If modifying, enter the new information, pressing the 'Enter' key to move to the next field.
Hope this helps!
Oct 15, 2009 | Toshiba DP80F Printer
Archos 604 wifi touch screen out of wak
I think you can use the keys ...
Boot up
Press the <> button on the left hand side of the menu key
Use the arrow keys to get to display, press ok
Scroll down to calibration, press ok
PK
Jan 08, 2009 | Archos 604 WiFi Digital Media Player
MP4 touch screen not working
my mp4 touch screen freezed and turned off. Now it wont turn on. please help
Sep 13, 2008 | Audio Players & Recorders
Iphone touch-screen
sir whats ur model\????
May 28, 2008 | Apple iPhone Smartphone
Problem with touch screen
what i tried was a warm reset, then doing the digitizer like 12,000,000 times.
Mar 02, 2008 | LG KU990 Viewty
P990i touch screen is not working properly.pls help me?????
go to control pannel
>>>>other>>>>setup wizzard>>>>>>keep it next next then u enter pen calliberation menu u will see 4 dots at 4 corners of ur screen touch on it exactly ur touch screen works properly
Dec 26, 2007 | Sony Ericsson P990i Cellular Phone
Magellan Maestro 4040 GPS Receiver Logo
413 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
