Question about Lakewood Oil-Filled Electric Radiator Heater
I need a wiring diagram for a lakewood 5500
Putting in the new switch and need a wiring diagram...already blew the fuses twice!!
  • pkarst Feb 20, 2009
    My switches light up but the heater doesn't heat up.
  • 34 Answers
Visit this page for service center info and or parts: they should be able to help you
Posted on Apr 18, 2009
Need a thermal cutoff for our Lakewood 5500
We have these heaters and haven't had a fuse fail yet. I think it's because after the first time I got that crackling sound after moving it while it was on, I stopped doing that, and only move it with the power off, and wait two minutes before restarting it, so the oil can resettle.
However, the thermostats are now failing. Anyone know if this part is available?
Apr 10, 2010 | Lakewood (5500) Oil Filled Radiator Heater
My lakewood oil filled heater model 5600/7 just stopped working. It won't turn lights. There is no history of tipping over.
The reason that it stopped is an open circuit. It is probably a blown thermal fuse. However, it could be any of the following if that is not the problem:
bad switch, broken or disconnected wire, burned open heater element, bad connections between terminals and wires, or between wire connectors and the wires within them.
If you take it apart, you will find the heat sensitive thermal fuse device under the heating elements, near the bottom of the unit. If the thermal fuse is good, it will appear as a short to an ohmmeter (zero ohms). If it is failed, it will appear as an open (infinite ohms).
The thermal fuse device can be replaced. Here is where to get one:
The thermal fuse may be this one, but check the temperature indication on yours first: Item#: TH-TF167C
Good luck.
Apr 06, 2010 | Lakewood (5500) Oil Filled Radiator Heater
I have 2 Lakewood 5500 oilfilled radiator heaters. The inline fuse has gone out in both of them. Where can I find this fuse?
Hi ladybug75846,
I have the same problem. My husband checked the continuity and found out the thermistor is the problem. The thermistor is stamped S.W.C. SW-122. If you find a source for these, would you kindly post it. Thanks!
Feb 26, 2010 | Lakewood (5500) Oil Filled Radiator Heater
The Lakewood 5500 oil-filled heater has stopped working. When switched on, it's indicator lights come on but the heater doesn't heat. I looked for a fuse but found none visible. What must I do?
Similar problem here. But in my case, it was a blown fuse. There's an in-line fuse on the internal wiring of the heater. Take the control-side off (remove the bottom grey plastic bracket, then remove a sheet metal screw, then slide the whole assembly down off of the radiator). Where the elements go into the reservoir at the bottom of the radiator, the white wire should have an inline fuse connected to it. It will probably be covered with what looks like heat-shrink tubing. Snip, snip, and replace.
Jan 08, 2010 | Lakewood (5500) Oil Filled Radiator Heater
Need wiring for on-off switch
Hi Joe. Typically the switch interrupts the hot wire, which is black. Therefore, two black wires are connected to the two screws on the switch. Look in the area where you see the one black wire and you should find a second black wire. Connect each of the to the switch and you will be switching [controlling] the hot [black] wire.
Dec 10, 2009 | Lakewood 7101 Oil Filled Radiator Heater
The heat no longer comes on.
The Lakewood 5500 heater may not heat, yet all lights are on, due to the thermal fuse inside the control box being blown.
It works like a normal fuse, yet will blow if the temperature gets too hot. When it opens, it will prevent any electricity to get to the heating coils and connot be reset. It must be replaced.
You can open the control area by removing the front foot of the unit, removing another screw behind that foot. This will allow you to slide the whole control end off the unit. At the bottom next to the heating element, you will notice 3 wires to the elements - red, blue, & white.
The white wire runs underneath the terminals & is sheathed. Under this sheath is the thermal fuse.
Be sure to replace it with the same temperature rating (167 C).
I don't recommend bypassing the thermal fuse, however, due to it's a safety issue.
I found the fuse at the following link:
Mar 25, 2009 | Lakewood (5500) Oil Filled Radiator Heater
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Aug 27, 2008 | Lakewood Heating & Cooling
Window Fan switch bad
Steve, Your fan model is HV-18-WR; I have 2 with the same problem. I can't find a source for DYE-3606 switches either. Here is one source for rotary switches; one might be suitable: I can draw a diagram of how the existing switch is connected, but I don't know how that would translate to a replacement switch.
May 22, 2007 | Lakewood HV12WR Window Mount Fan
Lakewood Oil-Filled Electric Radiator Heater Logo
1,024 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
