Question about Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-SD won't ring
We recently had a new Toshiba DKT2010-SD phone installed into a room, however we cannot get the phone to ring when recieving an incoming call. The light flashes indicating which line is in use, and we can answer incoming calls from the phone but it will not make a sound to indicate that we have an incoming call. So far, we have tried to change the volume using the volume buttons, and we tried unplugging and then re-plugging the phone but neither corrected the problem. The way it stands now, we cannot tell if there is an incoming call from that phone unless the call comes in as we are looking at the phone and see the light flashing.
The phone will ring when the volume buttons are adjusted, however even turned up all the way the ring will not sound during an incoming call. Does anyone have any ideas on how this problem can be fixed?
  • Anonymous Feb 24, 2009
    same problem
  • 38 Answers
Ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Posted on Feb 27, 2009
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
Please provide website that I can download operating manual for the Toshiba phone system DKT2010-SD Thanks!
Try www.toshiba.com and look for driver downloads to see if they offer a manual download for your model. Next try customer support if you come up empty.
Jan 14, 2011 | Toshiba DKT-2010 Corded Phone
Please download me instructions on how to change time in our Toshiba Phones at work with Model No. DKT2010-SD. Also I am requesting a Manual for the Toshiba DKT2010-SD phone system. Your tech support...
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial As far as the system manual goes, I'll need to know the type of system you have. Toshiba DKT2010's work with a number fo different Toshiba systems. To find out, go to where the phone system is located and look at the top corner. It should have a number designation there such as DK 40i or DK280 etc.
Nov 08, 2010 | Toshiba DKT2010SD Phone
Wont Ring, Wont pick up another line, upgrading phone lines
You will have to do a little programming to accomplish this. I attached a website to this message that has all the Toshiba manuals. You will have to look at program number 16 for line access and 81 for ringing options. The code to get in program mode is *#*#1*2*3. Hope this helps.
Feb 16, 2010 | Toshiba DKT2010SD Phone
I have a toshiba dkt2010-sd that I need to mount to the wall
The base is removed and turned 180 degrees and put back on phone notice the slide tabs are in correct position and can noe be hung by screws or a wall jack. Where the cord plugs in there is a breakout tab, that is the insert to hold the reciever on the phone when hung up.
Sep 09, 2009 | Toshiba DKT-2010 Corded Phone
How do you change the number of rings before the voicemail will pick up on a toshiba dkt2010-sd
Do you have a display phone? does it say something like CF/NA to XXX in the top? If it does press Intercom #603 then the XXX from above press Speed Dial then the number of seconds to wait usually 24 then press redial. If it does not have that displayed it is adjusted through voice mail programming. the admin program and guides for your phone can be found here
http://guides.idacomusa.com/
Jul 28, 2009 | Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-sd ringing in ear while on a call
1) To stop the ringing in your ear, press Redial and Vol Down at the same time
The following must be performed from station 10 or 200.
2) To change date : Press INTCM, #, 6, 5, 1, Enter date YY/MM/DD, press redial
3) To change time : Press INTCM, #, 6, 5, 2, Enter time HH/MM/SS in 24 Hr Format, press redial
4) To change day of week : Press INTCM, #, 6, 5, 3, Enter day (1=Sun, 2=Mon...), press redial
For more information regarding your Toshiba DKT 2010 Phone and the system that you're using, feel free to browse our extensive guides and manuals that you can find here
Or you can call me at 1-800-903-9190
May 05, 2009 | Toshiba DKT2010SD Phone
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
Changing Voice Mail Password from the TOSHIBA DKT2010-SD set
you will need to download the manuall you should be able to get it off this sight hope this is some help
Oct 30, 2007 | Toshiba DKT-2010 Corded Phone
Toshiba DKT-2010 Corded Phone Logo
1,222 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
