Question about Landice L7 LTd Pro Sports Trainer Treadmill
Landice L7 Sport Trainer stops and restarts randomly
After walking or running for a little while, it will slow down or stop all together and then restart. A red LED on the board with "SPEED" beside of it blinks once, as the motor surges back up to the set speed. The motor isn't hot at all, so I don't think it's overheating. Could there be a overspeed protection device that's bad?
  • 1 more comment
  • darronehill Feb 13, 2009
    CORRECTION: The red LED that blinks says "LED1" beside it. The "SPEED" LED is constantly illuminated, but goes out when the treadmill cuts out.
  • darronehill Mar 02, 2009
    No, it's not under warranty.
    Sergeant:
    Novelist:
  • 277 Answers
No its the problem od motor connections on the board which gives command to the motor to spin that is faulty as getting loose.just remove that connection and refit it properly firm and tight.
Posted on Mar 02, 2009
  • 564 Answers
Jus give me minute. Let me Check the manual.
  • 13,433 Answers
Is it still covered by warranty?
  • Ekse Mar 02, 2009
    do you regurarly perform maintenance on the unit? if not something is most likely breaking down, here are maintenance nstructions and dealer locator is also available on the page for repairs.
    http://www.landice.com/Pages/treadmill_r...
My micro yorkie is blind about 7 days ago he started walking with his head tilted walks in circles. What causes this? He is 4 1/2
Could be an inner ear infection. Which will upset balance. For treatment antibiotics are usually used. I would highly recommend a vet as antibiotics are only available via prescription.
Jan 13, 2017 | Exercise & Fitness
My Johnson T7000 Treadmill stopped running and displays Error 1-A0. Please help!
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 12, 2017 | Exercise & Fitness
Pro-form 650 cross trainer - when started the belt goes fast for 3 seconds and stops.
The Motor controller board is faulty. That's why its runs on the Top speed and and shut sown due to the over current consumption
You have to replace the motor driver or get it repaired.
Jan 10, 2017 | Exercise & Fitness
I have a maxed treadmill mxe 560 and everytime we start it up 2 mins in it stops and shows error 02...why?
You have to check the speed sensor and its position. may be the speed sensor is faulty or there is some dust accumulated on the speed sensor. also try to position it properly.
Jan 09, 2017 | Exercise & Fitness
Why does my proform xp 400r keep beeping even when it is not being used?
Did you ever find a resolution for this issue? I know it was posted over a year ago, but now mine is doing the same thing, randomly beeps 3-4 times rapidly whether or not is in use and never shuts off. Also none of the buttons work, just makes it beep as well. However, it still responds when pedaling and adjusts the resistance, just can't select a workout mode. Can only power off by unplugging otherwise the display stays on and keeps beeping every ten seconds or so
Dec 10, 2015 | ProForm XP 440 Recumbent Cycle
Schwinn srb 1700 will not read the speed or RPMs and the unit turns off after 5 minutes by itself. I was thinking of replacing the sensor but I can not find the part online. Any help would be great.
please see the video and lube the rollers bearing front+back too
2) Run the software calibration for easy diagnostic with sensor speed.and fix it.
Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Oct 01, 2013 | Exercise & Fitness
Landice L7 LTd Pro Sports Trainer Treadmill Logo
246 people viewed this question
Top Landice Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Duff Howell
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
