Question about Jensen VM9510 Car DVD Player
Hooking to amps to a power acoustik ptid-7250n
I have one amp for the sup woofer and the other amp for the car speakers. so i have three rca jacks running to the dash one set for the sub i know where that goes but excatly where do i hook up the two sets of rca jacks
    Sniper:
  • 86 Answers
Can you post a bit more about the components, as in the make and model of each?
  1. Head unit in the dash
  2. Sub amp
  3. Stereo amp
Posted on Feb 13, 2009
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
I have a power acoustik 0V4-1200 amp and 2-12" kicker cvr dual 2 ohms. My amp keeps getting really hot and turning off. I have two pair of rca jacks from my cd player to the amp. One speaker hooked up...
i have found the specs to your amp. 1. Amplifier connections: Lets make things simple. As we look at the amplifier speaker connections, we will number the outputs 1 2 3 4 from left to right for the top connections and again 5 6 7 8 from left to right for the bottom connections. 1 should be connected to a positive (RED) (+) on sub woofer A on voice coil (a) 4 should be connected to a negative (BLACK) (-) on sub woofer A on voice coil (b) Now using a small piece of cable, connect negative of voice coil (a) to positive of voice coil (b) Follow the same procedure for the other sub woofer using 5 and 8 as 1 and 4 This configuration should make the amp run at 4 OHM BRIDGED x 2. i hope this helps. dreamsystems
Feb 07, 2011 | Car Audio & Video
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Mar 29, 2009 | Boston Acoustics BA735 Computer Speakers
Sub woofers and amp
first of all is the amp a four way amp? if so then you need to know what the watts of the subs are (you dont want to melt them) wire + and - of channels 1 and 2 to one sub and + and - of channel 3 and 4 to second sub, nice thick lead from battery positive (fused) to positive terminal on amp thick lead from a good earth point to negative terminal on amp run a set of rca leads down the opposte side to the positive wire to prevent interference, run thin wire from remote wire of radio to the remote terminal of amp, rca's are plugged in at stereo and at the am. may need a RCA splitter to be able to power all four channels
Good luck Davelee
Mar 24, 2009 | Car Audio & Video
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Jensen VM9510 Car DVD Player Logo
140 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
