Toshiba Satellite L455-S5000 (4400 mAh) Logo
Posted on Feb 17, 2013
Internal microphone not functioning - Toshiba Satellite L455-S5000 (4400 mAh)
How to turn microphone on
Acer laptops feature on-board microphones for sound recording purposes within Windows.
Since an internal microphone can be a very handy tool for communication and speech-to text capabilities, working without a functional mic can severely hinder work flow for many users.
If you do not have any prior knowledge of how to repair a non-functional microphone within Windows, you may feel the need to send off your Acer laptop for repair.
There is no need, because even the most novice Acer user can do it.
Go to "Start," "Control Panel," then double-click on "Add/remove Programs."
Click on the "Windows Setup" tab, "Multimedia," then select "Details."
Choose "Sound Recorder" from that screen, then click "OK."
The Sound Recorder application will begin to run. Step 4 will begin the microphone test.
Click "Record," which is the circle located on the right side of the user interface.
If you hardware device is functional, you should see the recording display begin to move.
Press "Stop," "Rewind," then "Play" to verify the audio that has been recorded.
If you are able to hear what the microphone picked up, but are having trouble hearing the microphone's input within other software, refer to the software's manual about proper configuration of the device.
If you were unable to record with your Acer microphone in Sound Recorder, continue to next Step.
Scroll your mouse over to the bottom-right corner of your computer screen and then double-click on the small speaker icon.
Slide the microphone volume slider all the way to the top and make sure that there hasn't been a mute check-box selected.
If you are still experiencing error while recording with your Acer laptop's built-in microphone, you most likely have faulty hardware that needs to be replaced by Acer directly.
How to turn microphone on acer
My microphone not working
Dear,
Hardware troubleshooting Depending on whether you are using an internal or an external microphone, follow the steps below to see if the problem is with the hardware.Show all ' Hide allcollapse_individual_default.pngTest the internal microphoneThe internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to capture sound more easily.
  1. Adjust the notebook screen to place the microphone in the best direction for receiving sound.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. When using the internal microphone, choose an environment without background noise.
  6. If the recorded sound does not play back, continue to the next section of this document.
collapse_individual_default.pngTest the external microphoneVerify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
collapse_individual_default.pngSet the default microphoneIf the external microphone is set as the default recording device, uninstall and reinstall the audio driver to change the default recording device to the internal microphone. The internal microphone should be the default recording device.To change the default recording device:
  1. Click Start , enter device into the search field, and then select Device Manager from the list.
  2. Expand the Sound, video and game controllers list.
  3. Right-click the audio driver , select Uninstall from the drop-down menu, and then click OK to confirm that you want to uninstall the audio driver.
  4. After the audio driver is uninstalled, click Start , enter backup into the search field, and then select HP Backup and Recovery Manager from the list.
  5. Follow the on-screen instructions to reinstall the audio driver.
The internal microphone is now set as the default recording device. Basic troubleshooting
The following are some basic troubleshooting tools that you can use to restore your microphone's functionality, depending on your operating system and/or software preferences. However, it is recommended that you first run the HP Support Assistant as it can scan your current system configuration to automatically determine if your notebook requires updated software and device drivers.
How do I transfer music from records to my computer without having my internal microphone add unwanted sounds to the recording?
Well that would be a function of your PC's microphone control. Dig it up under advanced Sound Controls (or equivalent) and turn it off.
Does the acer 7715 have an internal microphone ?
Computers recently innovated either as web camera integrated performs audio video functionalities. Observe the computer devices built-in camera situation to ascertain the integrated microphone to capture audio experiences. Manufactures specification would least make an over impressed audio video structures however capable of capturing either multimedia expectations. Prior ascertain the computer devices features with navigating to attain the multimedia programs from where functionalities are attainable.
On my i mac i can talk on skype thru my headphones but it wont let me talk without them, so was wondering what went wrong?It was working before..
holding option while clicking on the volume icon (speaker) will bring up a small menu, make sure the 'input device' is the internal microphone.
if that doesn't work go to System Preferences -> Sound -> Input and select Internal microphone, it might need to be turned up. From that screen it can be tested to make sure it's functioning and picking up sound
5helpful
2answers
Internal microphone
Hi
check the Toshiba website for windows 7 drivers , download everything , bios update etc
click here for the link
Internal microphone lattitude E6400 and sound card in general
You can download the required installation drivers from manufacturer's site by clicking this link
Select and download the drivers according to the operating system of you computer (Win XP/Vista,others...)
3answers
Does my lapyop have an internal microphone
I found several variations on that model but I don’t see any with a built in microphone. Good Luck
18helpful
2answers
Can't find microphone on dell latitude D410 to skype
Checked on the Latitude D410 and it does not have a internal microphone ... the microphone connector is located on the right side of the laptop near the back ... you will need to purchase a separate mic to get this functionality ... these are fairly cheap to purchase
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
