Question about Dell Dimension C521 PC Desktop
Blue error screen and system shutdown on Dell Dimension C521
My Dell Dimension C521 periodically shuts down during operation, displaying a blue error screen. Sometimes it reboots automatically, and sometimes I must restart the computer. Why gives?
  • 106 Answers
Check your RAM. maybe your RAM is Damaged or lose in connection..
Posted on Feb 13, 2009
    Sergeant:
    Champion:
  • 237 Answers
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
What operating support system is compatible with Dell Dimension c521?
Windows Vista and windows 7 both work on this pc i installed windows 7 it works just fine.
Jun 17, 2014 | Dell Dimension C521 PC Desktop
Dell Dimension 3000 blue screen error with writing that say attemp to fix windows
First of all you have to identify the blue screen error code. Blue screen errors normally occurs due to infected windows files. You need to scan PC to remove malwares, junk and virus.
Also update the drivers that control your PC.
To fix this problem instantly use system optimization tool like Reginout.
Mar 27, 2013 | Dell Dimension 3000 PC Desktop
SCREEN HAS GONE BLACK ON MY DELL DIMENSION C521 PC, AFTER IT FROZE AND I SHUT IT DOWN BY PRESSING THE BOTTON. TRIED ALL SORTS OF
hello if your screen goes black and you press down this combination keys together window +Alt + delete and still it did'nt restart itself so you can use it then check your monitor cable that enters the back of your system. If the problem persist then you will have to reload your system operating system put in the window Xp or Vista CD and follow the command giving to you then if you are sure that the monitor is not the problem may be it has completely get fault that will need for another monitor
if you need more assistance pls get to us ok
Feb 20, 2010 | Dell Dimension C521 PC Desktop
Blue screen Dell Dimension C521
This problem occures when ther is an conflict with drivers, so try to updat your Bios from dell web site orm you may try to update the video driver or have an option to replace it and try Try to boot the system safemode and chk if you get the same BSOD if not then its the video drivers
Regards
Samson Ved
Feb 05, 2010 | Dell Dimension C521 PC Desktop
Freezes during start up
My first plan of attack would check
Second the event log in the BIOS, looking for a heat event. Make sure your fans are spinning, while you are in there get a can of compressed air and blow out any and all dust. Sometime it becomes necessary to remove the processor and put a little Artic 5 between the cpu and the heat sync.I would check out the video card, the easiest thing to try first is to remove and update the video drivers. I still lean towards the heat event Idea...
Hope this give you a headstart in the correct direction. Good luck,
PS, if you are the one shutting it down and rebooting, look to the Video Card,
Apr 25, 2009 | Dell Dimension C521 PC Desktop
Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Feb 19, 2009 | Dell Dimension C521 PC Desktop
Blue Screen Error Message
Looks like you've been getting two different Stop errors...
The 1st error, 0X00000024, aka Stop 0x24, is a Windows 2000 error. (XP is just an updated version of 2000) Microsoft gives an explanation here.
For the 2nd error, starting with 0x000000ED, Microsoft's solution is here, with additional help here.
Jan 02, 2009 | Dell Dimension 3000 PC Desktop
My Dell Dimension 4400 running windows XP Home Edition stopped working and displays a blue screen with the following message: STOP: c000021a {Fatal System Error} The windows Login Process system process...
If that is not it reistall and to not loose you files click you partion durring the install and do not format it and click enter then click on leave partion alone
Dec 07, 2008 | Computers & Internet
Abnormal shutdown, can't restart
This is going to be one of two things. 1- An operating system error or hard drive failure resulting in operating system error. 2- A component failure or bad/loose connection that is shorting the system and causing the system to think there is an operating system error resulting in a blue screen. First, try to do a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If you have any issues during or after the format and install, then the hard drive has failed and will need replaced. If the repair, fresh install, or new hard drive (if you get this far and opt to purchase one) are successful and you get a blue screen to the effect of "detected a problem and had to shutdown, check newly installed hardware" then most likely you have a loose connection inside the machine. You will need to take the machine apart and check all connections. If the connections are good, then you have a failed device somewhere in the machine, and will need to take it in for diagnostics. I know that the latter sounds difficult and rather scary, but I believe that you're going to find this to be a simple operating system glitch or failed hard drive. If you have any other questions feel free to ask, and let me know how the repair turns out.
Aug 04, 2008 | Dell Inspiron 1000 Notebook
Dell Dimension C521 PC Desktop Logo
267 people viewed this question
Alun Cox
