Question about Hoshizaki Commercial Freezer KM-500MAH
Ice Cubes won't drop
I've got a Manitowoc Series 150 Icemaker, and the last problem I have to fix on it is acheiving the proper balance so that it's far enough back that the water curtain coats the ice tray enough to get ice cubes forming (and doesn't drip out over the front of the trough), and far enough forward so that the ice cubes actually drop out of the top and down into the bin.
No matter how much fiddling I do, during the harvest cycle the ice cubes still seems to drop part-way out of the tray, but get stuck on the bottom and the whole sheet of cubes just leans out onto the plate, but isn't at the right angle to swivel the plate out of the way in order to let the cubes drop out.  (like this --->   |//   )Then a new cycle starts, water cascades over the stuck sheet of cubes, and pours down into the collection bin - melting any ice successfully formed.  :(
So, I use up a lot of electricity and still get no ice.
I've fixed EVERTHING else on this machine, just not this.
Very frustrating.
  • 1 more comment
  • creativechem Feb 15, 2009
    So, something strange happened.
    I was doing P/M - cleaning the ice machine, removing scale, and cleaning the ice tray (nickel plating is a little spotty in a few places).
    After I rinsed out the machine and tried to start it up, at first, the water pump wouldn't run in the freeze cycle, and then one it finally started up, it would shut off after a few seconds (CLICK - sounded like the harvest cycle started.) The next day - it's freezing ice again, but the cubes are still not dropping. Weird. Could have been something to do with the ice bridge probe...
    Happy that it sorta "fixed itself" and I can manually drop the ice and at least get SOME - but still troubled that it's not working quite right.
  • creativechem Mar 20, 2009
    Great suggestions, the only issue that could be making a minor contribution to the problem is the water curtain hole where the plastic pin expands into is cracked -so I fixed that with cyanoacrylate.
    I had a distributor ask his HVAC guy, and they didn't have much to suggest except adjusting the ice bridge thickness. I wasn't sure what that would accomplish since the whole sheet was releasing, just not falling into the bin, but I turned the adjustment screw down 2 full turns (!) until the ice started to fall into the bin in a sort of haphazard fashion. Tilting the machine forward helped to provide enough momentum to the falling sheet to have it function pretty reliably for the past several weeks.
    I have photos of the Ice tray, showing clear vacuum-release holes, some flaking of the plating, and the style water curtain used.
    Not sure how to post / link to those ...
    But thanks for all the thought and helpful input. It might all help me get this dinosaur up and running the NEXT time it fails!
  • steve
    steve May 11, 2010
    You are undercharged on refrigerant or you have a inefficient TXV or hot gas bypass valve.
    You also stated the plating is deteriorated in places. That alone causes the slab to stick.
    What are your pressures at the beginning of freeze and at harvest initiation?
    How much time from freeze to harvest?
    How long in the harvest mode?
    Ambient temperature in the room?
    Water temperature entering machine?
    Is the water valve or purge valve leaking?
    Guru:
  • 462 Answers
Something is holding your Ice Slab at the bottom from your description.
Some causes are
1 Dirty - scaled up evap, or just dirty w muddy covering,
2 the vacuum breaking holes are stopped up If it is making a sla whith the evaporator warm no ice take a flashlight and hold it where its shining to the back of the evap and look for the light on th cube forming slots next to the ones your shining the light into Upper corners of each hole must be open.
3 The slab is freezing uneve most like cause is a stopped up distributor tube at the top thats feeding the water down the evaporator.
4 On some models thay had a closer fitting water curtian (the cover in front of the slab) and the top of the sheet touched this and caused the slab to stay uprite and continue the "slide" forward.If your curtian is of the older style and has metal hooks on it with verticle slots n the curtian look at the slots and see if the slots are worn making the whole curtian slide down ward I have seen this several times.4B On some older models there is also a plactic coated wire diverter on the bottom infront of the evaporator. If the palstic coating is gone or the bottom or is not even, the slab could hang up there. 4C If you have the newer plastic pins make sure thay are seated in the mounting properly.
5 Nickel plating could be comming off (any copper color on the lower 1/3 of the evaporator?).
6 I have seen some of the horizontal plates them selves be loose and not in flush try pushing and pulling on them especially the ones at the bottom. ANy that are loose and comming out is your problem.
This lengthy extrapolation is by no means all of the possibilities but most of the common ones. If this helps you solve your proble please rate me accordingly. If it leads you to the correct and completed repair WOULDNT WE MAKE A TEAM?? And Good luck to you.
Posted on Mar 18, 2009
  • Farley Redfield
    Farley Redfield Mar 18, 2009
    Oh yes I hate to ask but if you get to the bottom of your problem please give me as high rating as you can I'm trying to get my % back up. If your still having trouble after this please post what you got to look at and what you did, I'll try to help you on through..
  • Farley Redfield
    Farley Redfield Mar 20, 2009
    Ok now that I remember what Im doing is the floor and machine level? Maybe its pitched slightly. The horizontal bars are at 15'. If its off a 1/4 bubble or even an 1/8th on a 2 foot level this will make a real difference. When cleaning it did you move it around? Bump it? re check the top from back to front on the sides (both sides with the top in place. And use the feet levelers to level as needed. See it has to be level so the 15' will help the slab fall off. And if your getting a whole sheet falling forward your thickness is ok. Its a problem if yuor sheet isnt thickenough or too thick. the bridge between the cubes should be about 1/8 to 5/32 thick. Thicker it wont break up when it falls and smaller it may not weigh enough or may sepperate and melt a lot of the slab before falling, and 1/4 of a turn CW is usually quiet a lot. does yuor machin ehave a red lite that blinks then the water touches the thickness probe? You can see it if you touch the probe while running if you have on. If you dont then your machine is older.
    Oh yes the water pump has a delay built in befroe it restarts. this is to let the evaporator place cool down befroe applying water.
    New Friend:
I realize this is a very late post, but it might help those who are currently researching the above problem.
I solved it by drilling a 3/8" hole through the center of the top half of the plastic curtain. I screwed a bolt into the hole from the outside and then placed two nuts at the end of the bolt to lock each other in place.
The purpose is to prevent the top half of the ice from leaning against the plastic curtain at such a sharp angle that it can not place enough leverage to the curtain to open it up while at the same time much of its weight is directed back towards the bottom of the icing unit. Hence, the ice hangs up and YES, the unit will either shut off in error or try to run water across it to remove the problem.
Not only does the simple bolt work like a charm but it causes the ice slab to fall out fast enough so as to allow the next freezing cycle to immediately begin without turning off for the 2 or 3 minute delay time which was typical when the slab had difficulty dropping, but would eventually do so and this became the accepted norm, until the above quick fix was applied.
Yes, of course cleaning is a necessary duty even with pre-filters.
I think I could get a patent from Manitowoc?
Hope this is all clear. I know how frustrating it is when everything else seems to check out just fine.
Posted on Aug 07, 2015
    Guru:
  • 1,524 Answers
The cubes are released by hot gas. So an undercharge will not allow this.
Posted on Apr 04, 2010
I have a Manitowoc 150 series and the cuber plate doesn't get hot during harvest (so the ice doesn't release). Eventually this trips the GFCI, and no ice gets made. Any help would be great.
Posted on Feb 14, 2010
  • 19,396 Answers
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on Apr 27, 2009
Icemaker is not working properly. It will only make ice after the reset button is pushed.
If the ice room is not getting/staying cold enough, the unit will not harvest the ice and proceed through the cycle... First step in troubleshooting is to determine if the compartment the icemaker sits in is cold enough, if it is, then you have to test the ice room temp. sensor to see if it is not sending the correct temp signal to the main board. These icemakers are modular and pretty much have to be replaced completely if the temperatures and sensor check OK. Samsung Refrigerator Temperature Sensor DA32 10104N
Jun 21, 2016 | Samsung RF263BEAESR Stainless Steel 26 cu....
Not making enough ice
Thank you for your inquiry, Herb!
I see that your Frigidaire refrigerator, FGHB2866PF, is not making enough ice. When is the last time you changed your filter? It is recommended to change your filter every six to nine months. If the filter is dirty the icemaker will not produce. You may also have a frozen water line and you can perform a manual defrost in order to clear out the line. To manually defrost your line you would need to disconnect power from it for at least three to four hours. If that does not correct your issue you may need to have a professional technician out to perform a diagnosis and repair. I hope this information is helpful. -Matt
Jun 11, 2015 | Frigidaire Gallery Series FGHB2866PF 27.8...
All cycles work except harvest manitowac ice machine
Ice thickness probe on Manitowoc and float switch may be dirty or stuck if hoshi. Manitowoc sometime the thickness probe can get dirty and a film of algae and not sense ice properly but rare
Oct 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
Ice maker is not making ice
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
Ice maker is not making ice. I can see no other problem and as far as I know the freezer was not left open as there is no frost buildup inside the unit. Everything is frozen, only problem is NO ICE!!
Pour about 1/2 cup of water into icemaker and see if it dumps the cubes after a few hours . If it does , and icemaker does not refill , then water valve is the problem . If the icemaker never dumps the water poured in , then icemaker is bad . ALSO , check to make sure the coils under refrig are clean of dust , lint , etc . Icemaker has to be 5 degrees to operate .
Jul 22, 2009 | Freezers
Help! my manitowoc! leaking!
I'm having a little trouble finding that model but if you contact them or can find a better or different number it may help. You can also contact them and order parts or order from one of their suppliers. Here is their link to home page. With the correct model number you can find your service manual and part number. Hope this helps. Manitowoc is pretty good about helping out. Sea Breeze
http://www.manitowocice.com/index.asp
Jul 18, 2009 | Freezers
Problem on Manitowoc Ice Maker Series 150
if the reed switch is not tripped at the end of the harvest cycle it will shut down. when ice drops it hits a cover with a magnet on the right bottom corner. the ice falling moves the magnet away from a switch and lets the sequence reset and start over.
Jun 12, 2009 | Beverage-Air 23.1 cu. ft. / 654 liter...
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Hoshizaki Commercial Freezer KM-500MAH Logo
3,386 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
