Old hoover top loading washing maching
Not draining out all old suds and doesn't seem to spin properly... tried with water only (to get suds out) but some water and suds still in drum and machine won't spin...
  • JOYCE BROOKS May 11, 2010
    This is joyce
    How old is your washer What is the model#? it may just need to be replaced the motor may be going out on it, not spinning fast enought to get rid of the suds, let me know the model # or you can go online and dowload your model #'s information fo to the type machine you have .com and then put in model # and go to that and then you will be able to find what ever you are looking for. but it sounds like machine is shot if its a older one. the moter is going to cost a good bit to replace, if you can find one for it.
    thanks
    joyce
  • 15,935 Answers
SThere is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
I still have wet close after spin cycle Why?
check the drain hose for any kinks in it,is it a top load or a front load washer and how old is it?the pump could be blocked with something or the tranny is bad.if it's a top load,set the timer on spin cycle,open the lid,start the spin and with a screw driver push down on the lid switch and see how the machine is spinning,if it's not spinning fast the tranny is bad.if the drain hose is stuck into a drain pipe pull it out and drain the water to see if the water is draining out good or partially draining,something could be in the pump or to much detergent,the washer can't pump out suds as fast as water then the suds turn back into water form again and the clothes are wet.
Apr 02, 2011 | Kenmore Washing Machines
Final spin cycle I get sud error code or f2, water mostly drained but no spin. When I restart the spin cycle just starts to spin then stops, sounds like it drains some more water then makes a small...
Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code SL or 5L?
It is Code SL which means Suds Lock. Either you have too much soap suds for it to drain properly or Your drain pump is clogged and not spinning properly. Try running it through a rinse and spin cycle and if you still get a code (SL or Ld) then you will probably need to replace your drain pump.
Oct 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Hoover washing machine model HNF71683D not draining water
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Feb 28, 2010 | Hoover Nextra HNF 3157 Front Load Washer
I have a hoover hsp15 select 1500 that wont spin or drain properly. Where is the filter so I can check that out?
The filter on most hoover machines is behind the kick plate at bottom front of machine.
Post back if further assistance required.
Thanks for using fixya.
Nov 29, 2008 | Hoover H130E Front Load Washer
Aquasmart too many suds
means that the pump might be blocked and not drains too well
Please check this link for all drawings and or perts you might need. Please clean pump out first
LINK
Apr 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Suds leaking from back of washer near top
Suds are not supposed to leak from the top; means you are not using the right detergent. Use front loading powders. You can open up the top during next wash to locate where the leak is coming from (after changing powder). I understand suds appear in the window during spin....but leak? Caution when machine works with top open!
rate if helped pl........
Dec 29, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
