Question about Canon PIXMA iP1800 InkJet Photo Printer
Cannon pixma ip1700 not printing
The Green light flashes once and then it flashes orange three times. Then it tells me to reload the paper. The paper is loaded fine. What's up with this and can I fix it tonight?
  • 565 Answers
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Posted on Feb 13, 2009
THE INK ABSORVER IS FULL
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Step 2 : Using software resetter
  1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
  2. Ekstrak/Unrar/Unzip the Software
  3. run GeneralTool.exe
  4. Select USB Port where the canon ip1300 or canon ip1700 installed.
  5. CLick Lock Release button
  6. Select EEPROM CLEAR
  7. Click Test Pattern 1 button
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
Resetting Ink-Waste Ov
Nov 27, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
I have a flashing orange light, flashing three times then the power light(green)blinks once, before the three flashes of orange again. I know this indicates a paper jam, but there is no jam. How do I...
You can't reset except by removing paper scraps. Try using an index card and gently push it backwards thru the rollers where the paper comes out to be printed. There are gears on the left side you can rotate to push the card to remove scraps.
Jul 02, 2009 | Canon PIXMA iP1600 Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Mar 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Canon Pixma iP1600 Printer problem
this is the service error download canon chip resetter utility, then reset your printer , download IP resetter utility
Nov 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Wont print, lights flash 1 green, 3 orange canon, pixma ip1700 paper is loaded
Go here. Type "three orange flashes" in the search window and click Search. You will get guidance on troubleshooting the possible problems. Note that if none work, it also provides information for getting the unit repaired.
Apr 22, 2008 | Office Equipment & Supplies
Canon PIXMA  iP1800 InkJet Photo Printer Logo
313 people viewed this question
old marine
old marine
