Question about RCA Universal Remote Control
I need codes for rcr4312w apex tv
I have a rcr312 remote but i dont have the codes.....i tried using the code search but it is not working. can someone help me or does anyone have the codes for apex tv
    President:
  • 415 Answers
Have Sanyo TV with Apex universal remote need codes
You can try code search on your Apex remote to find something that handles some or all functions of your Sanyo TV. If a search through all codes stored in the remote fails, you may have to try a different universal emote. All universal remotes do not store all possible codes.
Nov 14, 2016 | Sanyo Televison & Video
Need codes for radioshack 4 in 1 universal remote for apex tv converter box
The code(s), if applicable, are stored in the remote. Use the code search feature to find one that will handle some or all functions of your Apex STB. If unsuccessful, you may have to try a different universal remote. All universal remotes do not store all possible codes.
May 02, 2016 | Apex Digital DT250A Digital TV Converter...
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    www.directutor.com/content/ge-universal-remote-instructions
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
I have an apex ld3249 tv with remote. The remote died a couple of days ago. I have had the tv for 6 weeks. A universal remote will not work. A new Apex remote is $60. Is this going to be an ongoing problem...
Hello
There is no warrantee for the remote control for any company's set. A universal remote should work with your Apex tv. I'll give you the model and codes for the remote that suit to your apex TV. Buy one and match it to your TV.
PHILIPS [CL 034] universal remote control.
Codes are:-
0023 0223 0123 0741
Proceedings
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 15, 2011 | Apex Digital Televison & Video
Need RCA SystemLink 3 Codes for an APEX TV
try code 236, works for my apex tv/dvd combo and a rcu300wbl remote
Jan 09, 2010 | RCA RCU300WBL Remote Control
I HAVE A PHILLIPS UNIVERSAL REMOTE AND NEED CODES FOR APEX TV
For the APEX TVs you must use the search for codes method in the universal manual. Phillips usually keeps these on their website.
Check out http://www.urc.philips.com/ to search for the manual online.
Aug 09, 2009 | Philips Magnavox Learning Universal Remote
I HAVE LOST THE MANAUAL FOR MY PHILIPS MAGNAVOX UNIVERSAL REMOTE
You don't need the whole manual for the Philips Magnavox remote fortunately.
If you want to reprogram it for the Apex TV, follow my directions exactly.
  1. Hold down the Code Search button (on the remote) until the light on it turns red and stays red.
  2. Let go of the Code Search button.
  3. Make sure to switch modes at this point to which device you want to program, I'm going to assume TV Mode since your post says "Apex TV." If you need help with Apex DVD codes, I can answer that one too :)
  4. As you Press the mode button and release it, the light should blink for a bit, so keep your eye on it because after it's done blinking it'll stay red.
  5. At this point the remote want's you to press a sequence of numbers also known as Code[s] or Code Entries. Either way these are what are in a table inside the manual that you lost.
  6. I'm going to give you two codes in case one doesn't work: 044 and 335 (one of those hopefully will work)
  7. If the code worked you'll know right away because the light will get mad and start blinking again, otherwise if it DID work, it'll just turn off (the light will anyway).
  8. That's it, I reccomend you test out your remote with the TV now and make it everything works. If something doesn't, try the other code. If it still doesn't work right, I'll give you some more codes.
Hope that helped,
-Cheers-
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
APEX 044
Mar 21, 2009 | Philips Televison & Video
Pansat 2700a remote control codes
try code 0156. If that doesn't work, try searching for the code using the remote. Direcections should be in the manual for the remote.
Feb 15, 2009 | Universal Remote Control 2700A DTV...
Program the RCA#rcr312 universal remote control
hold the code search buttton until light comes on then select the device you are programing and enter code
Oct 22, 2008 | RCA Universal Remote Control
Code for apex tv through philips universal remote
Try these APEX TV codes 0023 0223 0123 0741 Thats from the CL034 Code book
May 02, 2008 | Directed 434MHZ Remote Control
Televison & Video Logo
134 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
