Question about GE 29385GE1 Speakerphone
Getting the phone from rotary to touch tone
How do I get my phone from the rotary mode to touch tone mode?
  • 68 Answers
There should be a switch somewhere on side marked pulse/tone, move it to tone
Posted on Feb 13, 2009
Is it possible to call out with this phone,it has an old fashion dial
I assumed your old-fashioned phone works in Pulse (Rotary) mode only. Maybe the Tel Company or the Private Tel Exchange in your house supports only DTMF (Dual-tone Multi frequency) or MF (Multi Freq.) tone.
Sep 05, 2015 | Lands Phones
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
The tone on my 2 portable DECT 6.0 phones was somehow changed- now every time I dial, I get the old rotary sound and I can not access any menu options. Help, I use my phone for work and need it fixed! ...
Your phone is somehow set to pulse dialling and you need to change it to tone. Instructions are given below.
Of course if you can't select menu options this will not work so please explain why the menu options are not available - what happens when you select the menu softkey?
Dial mode
The dial mode is preset to tone. If you do not have touch tone service, you need to change the setting to pulse.
To change the setting:
Press the MENU softkey when the handset is not in use.
Press or to select SETTINGS, then press the SELECT softkey.
Press or to select Dial mode, then press the SELECT softkey.
Press or to choose Tone or Pulse. Press the SET softkey to save, or press the BACK softkey to exit to the previous menu.
Feb 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Model UNIDEN UCIS-225 - Phone suddenly dials like a rotary phone. Does anyone know how to make it return to the non-rotary dialing?
two places<br /> 1. Manual switch on back of phone Tone or Pulse<br /> 2. Menu-Set Dial Mode - DTMF (tone) or Pulse
Aug 05, 2010 | Uniden Lands Phones
Can't get phone to switch from rotary dial to plain dial tone
Hi, there should be a button located where the power cord and telephone line hook up, It says pulse/tone, Make sure it is in TONE mode.
May 14, 2009 | Uniden 2.4 GHz Expandable Phone System...
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
GE 29385GE1 Speakerphone Logo
300 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
