Question about Amana AKS3040 Gas Cooktop
Gas ignitors continue to spark every 5 seconds in off position
With all the burners off, the ignitors all spark every 5 seconds. This happened before a month ago, but stopped after I turned some burners on and then off again. I've tried turning all the burners on/off, but the sparking won't stop this time. Is this dangerous? What could be the cause? I had just cleaned the cooktop. Maybe water caused it? I burned the flames for awhile hoping to remove moisture, but no luck stopping the ignition sparks..
  • theresa_n_ja Feb 13, 2009
    Thanks!!!!! :)
  • Anonymous Apr 20, 2009
    Gas ignitors continue to spark every 5 seconds in the off position. I have unpluged it and pluged it back in same problem.
    President:
  • Amana Master
  • 2,651 Answers
Try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Posted on Feb 13, 2009
The ignition - clicking - continues after burner has lit - all 5 burners have this issued
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jul 31, 2011 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
I have had my cooktop for 5 years The ignitor stays lit when cooking and I have had to replace the ignitor for the grill 4 times. Why is this happening?
You are getting too much water around the knobs...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
heatman101
Jan 12, 2011 | KitchenAid Architect KGCP484KSS Gas...
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
GE ZGU650 EM1BG Gas Cooktop
On any range I've seen with electronic ignitors, the valves have a position that closes a contact to turn on the ignitor and manually moving the dial to the 'Hi' setting opens the contact again and the ignitor ceases to spark.
You don't mean the ignitors run even when the burners are off, do you?
I'm surprised to read that this has been happening for 'years,' the transformer for the ignitors must be really tough to withstand that and it doesn't sound like an electrode or transformer problem but rather a contact not opening as it should or you not advancing the control past the ignite point.
Oct 18, 2008 | GE 30 in. JGP336 Gas Cooktop
Ignitors Continue to Spark
Turn the knob back towards off about 1/8 of a turn and you will take it off lite and it should fix it.
Aug 27, 2008 | Thermador 37 in. SGSX365 Gas Cooktop
Continual clicking of the automatic ignitor even when burners are off
some JA models i have seen the the spark switces are poorly constructed or improper installed from the factory and beging to become a probelm after a year or so of use. this is not a gas pressure issue it just plain ole' bad spark switches
Sep 05, 2007 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Amana AKS3040 Gas Cooktop Logo
474 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Ted Maxwell
Paul Carew
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
