Question about Garden
Belt assembly on a garden star tiller
My husband and I had to replace a belt on our tiller, the new belt is thicker than the old one and the tiller now walks all the time..does anyone know where i can get a manual for this kind of tiller to check and make sure the belts are back on right??
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mrs s,i couldn't find anything on a garden star tiller.perhaps if i had the brand name,model number,type number,i could perhaps find something,or you could go on line too.hope this helps.let me know.
Contact Northern Tool and Equipment: "Ardisam 5.5 HP Rear Tine Rototiller" (they don't call it a GardenStar anymore) it is Item # 26289.
Buisiness/Consumer Sales: 1-800-221-0516 (24/7)
Customer Service: 1-800-222-5381 (8-5 cst m-f)
Product Information Assistance: hal@northerntool.com
My wife and I are dealing with this as well. We can't get ours to go in reverse now.
Posted on Mar 29, 2009
  • 137 Answers
The belt is no doubt on right but if the belt is thicker than the old one it will continually grab onto the side of the pulley causing enough friction to move the tiller, this could be kind of dangerous.
I'm sure you were sold the wrong belt, if you still have your old one take it with you when you go to get another belt and don't let the salesman tell you that's the right belt.
Posted on Feb 15, 2009
Honda FG garden tiller 110, stoped running, took it apart, the timing belt loose, what do I need to fix it? Or is it worth fixing?
I'm not aware of them having a timing belt. Do you mean the drive belt? if so, it is supposed to be loose. in the disengaged position. and tight in the engaged position. and to answer your question it is almost always worth fixing. unless you have a lot of money and want a new one. I've seen tillers 30 and 40 years old work just as good as a new one.
Jun 22, 2016 | Honda Garden
Drivebelt routing diagram for a troybilt pony lawn tractor
oh oh big trouble...make sure you installed correctly re check ever thing is there a twist in the belt? not riding true on idler pully? correct belt?is belt cutting into guard housing any where? is the belt making howling noise? use veernier caliper to check dimensions of old belt to new belt.I once x out a drive belt with a generic one that did the same thing. my solution dont buy cheap chinese belts stick to OME belts as the chinese ones may not fit as intended.
Jul 09, 2014 | Troy-Bilt Pony Garden Tiller
My drive belt broke and I can't get a number off of it. Do you know the number for this belt?
Hello, W/D here.
The easiest fix is to take the old belt to an auto parts store and obtain a replacement. All "V" belts are interchangeable. All that's required is the "V" size and belt length, and you'll be fine. Getting "the exact replacement" from Troy-Bilt isn't necessary, and you'll save much by going in this manner.
Best regards, --W/D--
May 03, 2011 | Troy-Bilt Pony Garden Tiller
I need a new belt on rototiller.
To replace your tiller belt you will have to :
Take a few pictures before you get started so you know how everything goes back together.
- 1) Remove the belt guard
- 2 ) Loosen the belt pulley and remove spring, remember how this was attached.
- 3 ) Pull the belt through housing and off of the transmission pulley.
Now grab your new belt and install in reverse order.
Feb 02, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have an old tiller all i could find out about it is the name of how made it wich is garden wayman.co.And, i dont know what size belts it takes?
1-800-269-6215 is the number to call to look up older garden way tiller, mtd build most of the tillers but some real old ones were made by bolens here is the link to mtd's parts ordering system and parts look up hope this helps http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_BuyMTDOnline_10101_19502_-1
Nov 22, 2009 | Troy-Bilt Garden
Changing the drive belt
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
Both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
mortimer5918@bellsouth.net
Mar 24, 2009 | Garden
New belts on Garden Star Tiller but now no neutral
It may be your belt tension or you may have the wrong belt it may be to short.
Mar 14, 2009 | Garden
Garden Logo
758 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
