Question about Bogen Communication Bogen / Manfrotto 516 Pro Video Fluid Head 516 Tripod
Manfrotto 516 head adjustments
I cant adjust this brand new head where the pan and tilt movements are fluid. It always seems to have a "catch" in the movement that creates a **** on the screen.
Any suggestions?
SOURCE: Manfrotto Tripod Ball-grip Head 322RC2
If you look on the ring that goes around the ball, on the side by the red tension gauge, you'll see an indentation. It is just barely visible on the product shot above.
In the hole, you'll find what looks like an odd shaped bolt. It is actually a threaded post inside a nut.
Use an Allen wrench (hex key) to tighten this post.
Be careful though, a little tension here goes a long way. You should probably turn it no more than 1/8 to 1/4 turn and then test it. If it still isn't tight enough, repeat until you are satisfied.
You should probably also talk to a trained technician at somepoint to see if the loosening is indicative of a larger problem. I really wouldn't know one way or the other. I just discovered the calibration post by taking mine apart.
Posted on Nov 25, 2007
pal03246
  • 726 Answers
SOURCE: 2003 maxima sunroof won't close
Sounds like the sunroof motor is out of time. Needs to be re-timed. There is a retime procedure, (that I would try first) but I don't remember the whole procedure. if you still have the problem, let me know and i will get the whole thing , from the service manual.
Posted on Jul 27, 2008
SOURCE: Tailgate won't lock on my
I have the solution to every one out there with tailgate lock problems......I had the very same problem but wasnt interested in getting a power lock.......Here goes.....it costs you some wd40 or liquid wrench.....nothing else......open the tail gate.....you will see the screws that hold the handle in place.....take off the two outer screws only....then pop off the handle cover....yes it does come off without breaking.....you will see something shaped like a "C".....it should move back and forth.....with the tailgate closed you should be able to move that "C" back and forth...it swivels on a pivot you can see in the opening above the tailgate handle.......this is the lock mechanism.....mine was seized up.....anyways......with the tailgate still closed squirt some wd40 or liquid wrench in the area directly above the tailgate handle........that "C" thing will move again and your problem is over...email me if you figured it out........
I was delighted with the fix.....and it's so easy to do.....then put everything back in its place......tell everyone you know....
Posted on Oct 07, 2008
2tone2
  • 7 Answers
SOURCE: 4T60E Transmission output shaft movement
Hi Caarl
The lateral movement in the output shaft is normal and nothing to worry about.
Posted on Nov 02, 2008
pincer
  • 377 Answers
SOURCE: Can I get a Service manual for a Manfrotto Fluid
TRY TO LOOK AT THIS FORUM HERE
Posted on Jul 08, 2009
Tripod not holding camera- tipping forward . bought used w/ no manual, Bescor TH-770. The salesman, and specs say holds 15 lbs. I shoot Canon 5D Mark II, w/ 24-70lens.Thanks for your partnership!
Hi, Paulisa,
It depends which head is fitted to your tripod, but in the illustration from Bescor themselves, it appears to be a pan-and-tilt head. Level with the tilt lever are apparently several adjusting screws - without the camera on board, in case of accidents (done it myself,and it's not a good feeling !), tighten all of these and see if the head will move in any direction. If it does, then the head has issues and should be returned.
If the head cannot be moved, then just experiment until you find out which adjuster affects movement in each plane - my guess is that it may be the lever to the left hand side of the head (not the one at the base, which probably affects movement in a horizontal plane).
When you are sure that you have sussed it, try again carefully with the camera attached - if there is still unwanted movement, then the head needs adjustment.
Dec 27, 2016 | Canon Cameras
How adjust the vertical viewing
are you just mounting a camera to the tripod itself? - you need to purchase a head as well - the head screws onto the top of the tripod, and then the camera fixes to the head, usually with a qr plate.
May 05, 2014 | Manfrotto Photography
How should fluid heads be stored?
Alisa: With all 'video tripod heads'...., regardless if the are the original 'true' fluid heads (that actually used a liquid (oil) to achieve 'fluid' type movements) or a modern professional 'fluid' head (that actually uses a clutch mechanism like a cars transmission) or a fluid effect head like the Manfrotto #501HDV (which used nylon discs sandwiching a ball bearing race)...., always store with the pan and tilt mechanisms unlocked!!!! This means the camera platform should be positioned in the 'rest' position (not tilted forward or backwards), also ensure that any counterbalance mechanism is released so as to eliminate strain on the internal mechanisms!!!!
If you remember to do this and don't overload the head..., you will extend the life of your gear significantly
Peter
Nov 12, 2013 | Manfrotto 501HDV Pro Video Head Tripod
What fluid do i need in my 3066 tripod
they don't use fluid - maybe some grease in the tilt and pan of the head, but the tripod itself doesn't need any.. you might need an adjustment somewhere... I own 3 of these.
Feb 07, 2013 | Manfrotto Bogen 3068 Tripod With Bogen...
There's a wiggle when I try to pan side to side (so there's always a slight **** in the video). This is a fairly new tripod (Manfrotto 7321yb), so not sure if it's a defect, or something that I need to...
The first thing that comes to mind with this issue is that this is not a real video tripod. This is a still tripod. With that said you might just want to try to make sure the pan/tilt locks are fully unlocked, then move the head back and fourth quickly (without the camera attached) for a few seconds to actually warm up the head.
Hope that helps!
May 03, 2011 | Manfrotto 7321YB Tripod
Head does tilt smoothly on 516. How do I get it smooth? Eric
Not fully understanding your question. You stated that the "head does tilt smoothly on 516. How do I get it smooth". What are you asking exactly? How to smooth out the pan as well, or how to make it tilt even smoother?
Sep 03, 2010 | Bogen Communication Bogen / Manfrotto 516...
The Pan Tilt Head cannot be removed from my Manfrotto CXPRO3
Extend the center column, there are 3 screws underneath that when unscrewed will allow the head to be tightened or loosened. The head is screwed on about 4 or 5 revolutions. You will need a flat head screwdriver. Take the center column out if you need to to be able to get to the screws.
Aug 24, 2010 | Manfrotto BOGEN 804RC2 Basic Pan Tilt Head...
I'm trying to attach a Canon EOS Rebel XS to a Manfrotto 190XPROB tripod, but the tripod socket on the camera is too small. How do I attach them?
You need a head. The tripod has a standardized screw for accepting a tripod head, which is a larger screw than for the tripod mount on the camera. There are a variety of heads available, ball heads, three-axis heads, geared heads, pan-and-tilt heads, and more.
Here's a page showing Manfrotto heads:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/1888?livid=80&idx=80
Aug 11, 2010 | Cameras
Which head do i buy with the manfrotto 055xprob
Any head that matches your requirements. Do you want a ball head? A tilt-and-pan head? How much weight will have it to support? The tripod comes without a head because no one except you can decide which is the best head for you.
Aug 02, 2010 | Manfrotto (701RC2055MFV) Tripod
FH101 head jerky panning movement
Not knowing where you reside, I don't know if a certain product is available to you but there are several different brands and some generics in the US. The original oil additive was called STP, there was a competing brand called Motor Honey (shudder) and in many auto supply houses you can find a generic sold for 'high mileage engines.' It is a refined petroleum product with a very high viscosity and is sticky in nature. If you can access the surfaces causing the problem, a dot ot two on either will probably help with the jerkiness you are having. I have used the stuff for similar gliding surfaces and the only disadvantage is the tendency to 'creep' so keeping the applied quantity low is a must.
Mar 08, 2009 | Swarovski Optik Swarovski Tripod 2 with...
Photography Logo
139 people viewed this question
Top Bogen Communication Photography Experts
pontelemon
pontelemon
Tony
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
