Question about Hobart Handler 140 Mig Welder
Hobart handler 140 will not feed wire
The welder welds and the relay clicks when i pull the trigger but the wire wont feed. I have tried replacing the small relay on the circuit board but it still wont feed wire.
  • 2 more comments
  • cssgoshen Feb 20, 2009
    I did that and the rollers do not turn. there is no voltage to the motor but the relay has 24 volts on its coil side when the trigger is pulled and the normally open contact short out when the trigger is pulled as well. The motor does show resistance so I think it is good. I tried replacing the darlington power transistor tonight but it still displays the same symptoms. I checked the varistor and it measures fine so i shorted it out and tried it but still no voltage. It would sure help if i had a schematic. I may have to draw one up but some of the traces are pretty hard to see. Any further help would be appreciated.
  • cssgoshen Feb 21, 2009
    I have all the original manuals that came with it but it does not include a schematic for the circuit board so i drew one tonight and will take some voltage measurements tomorrow and fix it for good.
  • Ron Jones
    Ron Jones May 11, 2010
    Remove the tension from the rollers, do the rollers turn when you pull the triger ? lets know..........
  • Anonymous Mar 26, 2014
    wire feed motor doesn't run
  • 39 Answers
Too much tension on the wire is as bad as not enough tension....If the feeder wheels are turning back off the tension and add just enough tension to make it feed the wire and check for birdnesting(the wire balls up inside the welder), if this happens cut the wire, pull out the bad wire and re-feed the wire again.
Posted on Aug 08, 2012
  • 92 Answers
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Posted on Feb 20, 2009
L bought a hobart 140 two days ago, welded about 10 feet of wire with it .now it only feed wire on three out of the five settings
Check the selector switch with an ohm meter. Unplug the unit, ground to chassis and probe the contacts while turning the switch on and off.
Dec 17, 2012 | Hobart Handler 140 Mig Welder
Hobart handler 140 mig welder gas wont shut off
Looking at the Hobart manuals, that is how they set them up at the factory.
One way to make a change to that is to wire in a solid state relay or solid state Triac and pick up an energizing voltage off of location RC2-1 or RC2-2 on the control board when the trigger is pressed, or as an alternate location from the feed motor through a resistor and rectifier. Once you know if the voltage goes low, or voltage goes high at your point of signal, you pick the contact you want on the relay so when the wire is feeding out, the gas is flowing. and when it is not feeding wire out, the gas is shut off.
Dec 31, 2011 | Hobart Welding Tools
I have a hobart handler 135
You do not indicate if the wire is already out of the nozzle. If not, commonly the wire can jab the side of the tube it runs through and cannot advance.
IF the wire is already threaded, then there MAY be a fuse to protect the motor.
The click MAY be the gas valve, or the relay driving the motor and/or the main transformer for welding current. The circuitry for these is relatively simple and a voltmeter is your friend to troubleshoot this.
Oct 26, 2009 | Hobart Handler 140 Mig Welder
Hobart handler 140 wire feeds properly, will not weld
If it is new i would not play around with the welder Just take it back to where you bought it get them to replace it under warranty
Jun 10, 2009 | Hobart Handler 140 Mig Welder
Wire burning betwen rool and feed drive
When you pull the trigger the entire spool of wire and anything metal that touches it becomes electrically hot. If the tail end of the spool is hanging loose and touches something on or connected to the chassis it will do that, and could have welded the connection so it's solid.
May 13, 2009 | Hobart Handler 140 Mig Welder
Handler 140 wire jerky when welding
make sure rollers are clean and slots not wore out check alignment
do not over tighten wire feed so it smashes the wire
flux wire is hard to get a good setting
make sure if you can set it for gas welding it is not on this setting
Apr 06, 2009 | Hobart Welders 500505 Handler 140 MIG &...
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
Hobart Handler 140 Mig Welder Logo
1,923 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
