Whirlpool Duet GHW9100 Drum Knocking/Plastic Tub Shredding
Our Whirlpool Duet GHW9100 was knocking during the high spin cycle. We noticed small pools of oil under three of the shock absorbers, so we assumed this was the problem and replaced all four shock absorbers. The knocking still occurred, and to make matters worse, the front of the metal drum (basket) appears to be rubbing on the inside of the plastic ''front tub,'' and the plastic is shredding off, literally, and pieces of plastic are ending up in the washing machine. We called a repair man, and he said the problem is internal to the drum (basket/tub assembly) and that it would be more expensive to replace the items than to purchase a new machine. He said he has never before seen this problem. The machine is almost 7 years old, so we are planning to replace it. Have you heard of this problem? We have never had any other problems with this machine.
  • u950 May 21, 2009
    we are haveing the same problem and the washer is also 7 years old but our tech said that the drum has lifetime warranty.
I have the same problem-also 7 years old. Anyone find out if it is covered by warranty?
Posted on Jun 27, 2009
I have the same exact problem. This is a drum bearing issue - since the drum has a lifetime warrantee, is this issue covered? Thanks.
Posted on Jun 22, 2009
  • JRMahon Nov 10, 2014
    Just following up after 5 years... hah. Anyway, GE gave me a drum for free, and I replaced it myself. They must know about the problem. the aluminum bracket that connects the drum to the drive shaft degrades and breaks, causing the drum to wobble and knock. Replacing the drum is not for someone who is not mechanically inclined. It's an involved process and takes a few hours. In any case, 5 years later the new drum is still holding up. I expect it to happen again, unless they just had a bad batch of aluminum brackets and my new one is different. We'll see.
    Scholar:
  • 99 Answers
This is joyce
The bearings is gone in the drum, causing the drum to rub and run the wrong way one the pully, yes it is very exspensive, I have the newer model.
let me know if I can help
thanks
joyce
Posted on Feb 13, 2009
Loud knocking and vibration during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer makes a very loud banging/knocking sound during the final spin cycle.
it sounds like you need a new inner tub,the three cross member sound like there broken
Mar 30, 2010 | Washing Machines
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Duet ghw9100 washer clunking noise on spinning belt ok tub supports ok white plastic collar in front part of tub is broken and shredding
With the machine off, push upward on the inner drum and release. If the clunking sound occurs and the drum seems somewhat loose, likely the front main bearing for the drum is damaged and must be replaced. Major tear-down!
Nov 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet WFW9200SQ has knocking sound located under drum under or near motor. Knocks during spin up and down cycle and on last highest spin.
the problem is a cracked spindle on the back of the drum. It most likely also tore up the grey plastic front shield.The only thing to do is throw the machine out sine the drum cost parts onle is over $400 for drum, and over $400 for the front plastic.l
Nov 12, 2009 | Whirlpool GHW9200L Front Load Washer
Nylon or plastic bushing around tub breaking down
sounds like you have abadrear bearing, not cost effective to repair by you, parts have a 5-10 yrs warr, you would need to check your manual, usuallt wind up replacing, the rear drum, inner basket, without warr theese parts are probalby 650 dollars. so i would call an authorized servicer(whirlpool wont send you parts even though they're warr)
Apr 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
WHIRLPOOL DUET GHW9100 FRONT LOAD
Take the top off the unit,and check the springs..there are 4 on top and 4 on the bottom..make sure they a attached..and tighten
Jan 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Knocking Whrilpool Duet
The "cleats" inside the wash tub are actually called "fins". If they are loose try tightening them to see if the sound goes away. You should be able to tighten them from inside the wash tub. Some models have mounting screws that are accessible from inside the wash tub. However, if your machine is knocking like you say it is, it could be sign that one or more of the mounting shocks under the wash tub could be bad, the rear tub bearing could be going bad, or the drive pulley could be cracked or warped. Remove the lower kick plate and watch the shocks during the spin cycle. The shocks should vibrate some, but should not be excessive to the point that it causes an unbalanced spin. To check the drive pulley, remove the 3 screws from the washer top in the rear of the machine. The top should slide back some and then lift off. Watch the drive pulley behind the wash tub during the spin to make sure the rotation is smooth and even. Sometimes one of the arms on the pulley can crack or become bent and cause the pulley to wobble. More than likely, though, the drive belt would slip off. I have also seen where the hole in the center of the drive pulley starts to "round out". The hole is not perfectly round and has to flat sides. Sometimes over time the drive shaft will start to slip around the flat sides, causing the pulley to rattle during the spin cycle. If the rear tub bearing is starting to go, the washer will be very noisy during the spin cycle, and you may start to notice some stains on your clothes if the bearing seal has been breached. You can reach inside the wash tub with the unit turned off. With one hand, push up on the wash tub and release. If you can feel the tub moving up and down (even the slightest) this could be a sign that the bearing is worn out. Now this should be a noticeable metal on metal type feel. Not the normal motion of the wash tub moving up and down from the motion of the shocks. The tub bearing is not a cheap (or easy) fix. The entire back section of the rear outer tub shell has to be replaced, because the bearing is molded into the plastic. Check all the easy things first. Let me know if this helps.
Jun 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
1,052 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
