Question about Ricoh Aficio 1013F Copier
How to print 17 inch paper on Ricoh AP 3800 C
How do I use the bypass tray for 11 inch by 17 inch paper in a Ricoh Ap3800C laser printer?
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Posted on Feb 13, 2009
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Jan 20, 2013 | Ricoh Corp Aficio SP 6330N Laser Printer...
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
I get the same message coming up "remove paper standard tray"
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Jul 20, 2009 | Ricoh Aficio AP3800C Laser Printer
Will only print some pages from bypass tray
if you load the larger paper into a tray then go into the printer properties from your printers folder on the pc you can force selection of a particular tray
Jul 08, 2009 | Ricoh Aficio AP3800C Laser Printer
I get remove paper standard tray on a AFICIO AP3800C and it locks up the software. Then does not allow clearing the message. I have removed paper. Tried Aux feed. Always does same thing
On the face down exit tray (one on top) there should be a 3 or 4 inch long plastic part sticking straight out and pointed down. That is the tray full sensor arm. It could be knocked out of the holder and now working right.
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Can't Print
Firstly, I have to ask......the paper is installed, and tray set correctly? Does it read the proper size on the display of the copier?
Ok....next, do you have the optional paper trays installed (3 & 4)?
Is that where the 11 x 17 paper is? Then you probably did not add the accessories when you installed the driver and when printing that paper is unavailable.
right click your printer icon, click "properties", then i think it's under the "accessories" , or "options" button....select the optional trays, and anything else you may have. click 'ok' ...should work.
Mar 19, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
My printer will only print from bypass tray. Why?
It may be something to do with the paper size settings on printer driver, document print settings or page setup. If for example the computer thinks the paper size is Letter, and the paper in Tray 1/2/3 is A4, it won't print.
Jan 23, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh ap3800
Try sending A4 or letter size to the bypass. if the same problem is risen then you will most likely have a problem with the bypass itself and nothing you have done or are doing.
The other way to check is to set a 11" x 17" in the second tray and try it that way if that goes through then there is no problem with the way you are doing things and the problem lyes with the bypass section.
Please try these and I hope they are of some help to you
Thanks J
Nov 20, 2007 | Ricoh Aficio AP3800C Laser Printer
263 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
