Question about RCA HD61LPW163 61" Rear Projecection HDTV
After a power outage, we had sound, no picture, now no sound.
The one light is on but all the blue squares are flashing
    President:
  • 415 Answers
Did you have your TV hooked up the a surge supressor?
Posted on Feb 13, 2009
Only 1 blue light on the r/h side of my desk top flashes
Hi
It sounds as if you have a hardware fault of some description, if this is the only light on. I would have expected a power light and also a hard drive light which would flash when the hard drive was in use.
If the light that flashes looks similar to this 25189261-ecr03dcbzepjo15qmujjabbe-1-0.jpg then this is a light for the network connector.
Cheers
Oct 06, 2014 | Acer Veriton M464 (4718235937997) PC...
Rca hdtv dlp screen flashing
Sounds like it could be the power supply. Try changing the brightness of the screen and changing picture modes like movie or standard. If this causes the flashing to change in severity, it will most likely be the power supply board
Dec 13, 2013 | Televison & Video
HP f1703. After a power outage, when computer is
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 19, 2009 | HP Pavilion F1703 17" LCD Monitor
Red light flashes,10 sec after turning on. after power outage
Hi, thank you for visit fixya.
Do you need replace both stk 392-110, and check any resistor (2.2 ohms) for blown or open. You can replace this IC's for stk 392-150d9f769b.jpg
May 12, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Power outage. the tv was off. when the power returned the blue power light was flashing and i have no picture or sound. the screen is black
People think. Lightning or surges will never get me so long as my TV which is directly plugged into the wall is off. :}}
I bet you $120.00 you did not have a 1000VA UPS on it. If I was right, you can pay me now, and I can send you one.
You need a new TV.....or it will cost you $150.00 to fix.
The thinner they are the faster they blow...by the way they have a computer in there.
www.storminprotection.com
Dec 16, 2008 | Polaroid FLM-2601 Television
X2GEN MONITOR LIGHT ON AND CLICKING
Hi...there,
Well, it is seems your monitor backlight inverter got burnt... need to replaced a new one or repaired it.
Dec 01, 2008 | X2Gen MG19MY 19" LCD Monitor
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Tv dont come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Nov 07, 2007 | RCA D34W135D 34 in. TV/DVD Combo
RCA HD61LPW163 61" Rear Projecection HDTV Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
