Question about Bionaire BCM5520RC Humidifier
Bionaire bwm5700 humidifier leaking (warm moist)
After filing in water and start it takes 5 - 10 min, then water is overfilling chamber where water tank is seating
sabharish
  • 297 Answers
SOURCE: HAVE LOST OPERATING INSTRUCTIONS FOR BIONAIRE
Here is the download link for the instruction manual :
http://www.bionaireuk.co.uk/Manuals/MANUALS/BWM5075C-IUK_43_7594830.PDF
It wud be great if you rate this solution!
Thank you!
Posted on Apr 03, 2009
  • 114 Answers
SOURCE: I have a bionaire model w-9 humidifier. the
currently through the information that i have seen right now, the regulators are out of stock. the best thing that i can suggest is try the manufacturer or local hardware stores. now if your in canada you can always try canadian tire. i will keep looking just in case you aren't able to find one locally.
Posted on Aug 20, 2009
  • 114 Answers
SOURCE: I dropped the tank. Whre can I get a new tank?
you can check any hardware store or if you live in canada you can check with canadian tire.
Posted on Aug 29, 2009
  • 114 Answers
SOURCE: replace humidifier filter
turn the unit off then take the tank off then the base which is the fan portion and the filter fits right there.. if it's a round filter then it slips right on. now if it's the squares they will slip into some slots and usually they will take about 4 if that's the case. if you have any other question please feel free to let me know.
SOURCE: Water tank broken
I broke my tank also and tried going to the Bionaire website and got no where. I still had my manual which had a Customer Support number. I called and got a new tank for around $15.00 plus tax and shipping. The number is 1-800-253-2764 and the representive was wonderful!
Posted on Nov 09, 2010
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But...
try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Mar 27, 2011 | Bionaire Humidifiers
Our HCM-640bw Honeywell humidifier will leak water onto the floor. If I fill the tank and let it sit without turning it on, no leaking. When it runs for about two hours it leaks bad. Any ideas on how to...
Found a hairline crack in the water canister. Had to locate by filling the canister and waiting for a couple of minutes for water droplets to form outside the canister. This ever so slight crack allowed air to enter the chamber and made changes to water dispensing rate which overfilled the resevoir over time ( hours). The cracks were not visible under 10X magnification without the water droplets.
Jan 18, 2010 | Honeywell QuietCare HCM-630 Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Bionaire BCM 6000 tower leaking issue
Thank you for the follow up but there was a price at the end for my question so I decided to find out myself. I bought this product which is not the greatest and if on top of that I have to pay for a little information that's a bit far !
Regards,
Michel
Feb 02, 2009 | Bionaire BCM6010RCU 3.5 Gallon Tower...
Cleaning
For Model V745A Vicks Warm Mist Humidifier:
Weekly Maintenance (Removing Scale)
  1. Turn the switch to off and unplug the corn from the wall.
  2. Remove Water Tank and empty any remaining water from the water tank.
  3. Remove Medicine Cup from the Cooling chamber from the Base. Carefully remove the Cooling Chamber and Removable Water Tray from the Base.
  4. Soak the Removable Water Tray in a solution of white vinegar and water for 20 minutes. Rinse thoroughly and then wipe dry with a soft clean cloth.
  5. Fill the heating chamber with undiluted white vinegar. Let stand for 20 minutes. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Heating chamber to remove scale. DO NOT use soap, detergents or abrasive cleaners.
  6. Rinse the Heating Chamber using clean warm water, being careful not to submerge the base in water.
  7. The Water Tray, medicine Cup, and Cooling Chamber are top shelf dishwasher safe.
May 23, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
Feb 07, 2008 | Bionaire Warm Mist BWM0400-U Humidifier
Bionaire BCM645 Cool Mist Humidifier leaking water
There is probably a crack somewhere in the unit. Not likely, but worth visually inspecting closely.
Try filling it with less water and run it and see what happens.
Mike
Jan 05, 2008 | Humidifiers
Bionaire BCM5520RC Humidifier Logo
239 people viewed this question
Top Bionaire Humidifiers Experts
Oloyede Monsuru
ray gallant
Think Crucial
Think Crucial
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
