Question about Toshiba Satellite A205-S4587 Notebook
My webcam didn't work since i purchase it
I have a notebook Toshiba satellite U405-S2824, Intel Core 2 Duo Processor T5550, 3072 MB PC2-5300 DDR2 SDRAM, 250 GB (5400 RPM) HDD, 802.11a/b/g wireless. Since i purchase it last month, the webcam didn't work well. I've already install the Camera Utility Tools but the webcam still didn't work. I don't know how to solve this problem.
I really need a help from FixYa community..
Plissss...
thanks before...
INSTALL THE DRIVERS WHICH YOU SHOULD GET FORM THE VENDOR THEN TRY.
HOPE ULL GET THROUGH THIS
Posted on Feb 13, 2009
Toshiba Satellite U405-S2824 startup beep code error
The beep you hear is a BIOS Beep Code. The computer's way of telling you something is wrong, and a general area to look into for it.
A short repeated beep over a long period, usually indicates a Ram Memory problem.
Remove ALL power to the notebook. Remove the AC adapter (Charger), and Battery.
Suggest you remove all ram memory modules, and clean the gold plated contact pins at the bottom.
Use a pencil eraser. If using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band touch the contact pins. Reinstall the ram memory module/s.
Reinstall the Battery, then the AC adapter. WAIT 1 minute, then turn the notebook on.
Post back in a Comment as to the results.
Regards,
joecoolvette
Dec 31, 2011 | Toshiba Satellite U405-S2824 PC Notebook
Is this laptop is wifi ready?
Yes it is wifi ready.
click me for more info
Toshiba review unit had the following specifications: Intel Core 2 Duo T8100 2.1GHz processor Intel X3100 Integrated Graphics 2GB RAM DDR2 15.4" WXGA 1280x800 screen Intel PRO/Wireless 3945ABG (802.11a/b/g) 10/100 Ethernet LAN Modem port VGA-15 pin DVD-SuperMulti drive (+/-R double layer) supporting up to 11 formats Headphone and microphone jack webcam Battery: 6-cell (4800mAh) Lithium Ion battery Weight: 5.7lbs
Sep 15, 2011 | Toshiba Satellite Pro L300 Notebook
Plz send the this laptop zenuan prizes and send this configrution i purchase on 14" tosiba laptop
Our Toshiba review unit had the following specifications:
  • Intel Core 2 Duo T8100 2.1GHz processor
  • Intel X3100 Integrated Graphics
  • 2GB RAM DDR2
  • 160GB (5400 rpm) hard drive
  • 15.4" WXGA 1280x800 screen
  • Intel PRO/Wireless 3945ABG (802.11a/b/g)
  • 10/100 Ethernet LAN
  • Modem port
  • VGA-15 pin
  • DVD-SuperMulti drive (+/-R double layer) supporting up to 11 formats
  • ExpressCard Slot
  • SDCard Slot
  • 3x USB 2.0
  • Headphone and microphone jack
  • webcam
  • Battery: 6-cell (4800mAh) Lithium Ion battery
  • Weight: 5.7lbs
  • Starting price: $949(about 40000 rupees)
The Satellite Pro L300 didn't have any problems running multiple programs or multi-tasking jobs with its Core 2 Duo 2.1GHz processor and 160GB hard drive. I could check email, open documents and surf the Web without any lag. The benchmarks are average and overall the L300 did good on its PCMark05 score compared to other notebooks in the same category. I am sure the fact it is running Windows XP instead of Vista helps out this business savvy notebook as well.
wPrime is a program that forces the processor to do recursive mathematical calculations, the advantage of this program is that it is multi-threaded and can use both processor cores at once, thereby giving more accurate benchmarking measurements than Super Pi.
Dec 17, 2010 | Toshiba Satellite Pro L300 Notebook
1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gcl
Intel E6850 specs sheet. http://www.dealtime.com/xPF-Intel-Intel-Core-2-Duo-E6850-Processor-3-0GHz-4MB-Cache-1333MHz-FSB-Conroe-Dual-Core-OEM-Socket-77
Intel E6700 spec sheet. http://www.dealtime.com/xPF-Intel-Core-2-Duo-E6700-2-67Ghz
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
$149.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3826343&CatId=2396
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
http://www.lagoom.com/KINGSTON_1G_DDR3_1333MHZ_PC3-10667/KVR1333D3N9_1G/partinfo-id-580235.html
I hope this has helped you make a decision proenza.
Good Luck!
Mike
Jul 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Buying a notebook
Please go for this my friend has bought its rockz man
Compaq Presario V6700TX series Operating system
s.gif Operating System
  • Genuine Windows Vista Home Premium (32-bit)
Processor
  • From: Intel Core 2 Duo Processor T5450 (1.67 GHz, 2MB L2 Cache, 667MHz FSB)
  • Up to: Intel Core 2 Duo Processor T7250 (2.00 GHz, 2 MB L2 Cache, 800MHz FSB)
s.gif Processor
  • Pentium Dual-Core Mobile Processor T2330 (1.6 GHz, 1MB L2 Cache, 533MHz FSB)
Display
15.4" WXGA high-definition widescreen with BrightView s.gif Display
15.4" WXGA high-definition widescreen display with BrightView Dimensions
14.05 (L) x 10.12 (W) x 1 (min H)/1.69 (max H) s.gif Dimensions
14.1 (L) x 10.11 (W) x 1.29 (min H)/1.58" (max H) Weight
5.99lbs
Weight varies by configuration s.gif Weight
6.4 lb.
Weight varies by configuration Communications
Available Intel PRO/Wireless 3945ABG network with optional Bluetooth s.gif Communications
802.11b/g wireless LAN Broadband wireless
N/A s.gif Broadband wireless
N/A Graphics
Intel Graphics Media Accelerator X3100 s.gif Graphics
Intel Graphics Media Accelerator X3100 PCI expansion
Expansion port 3 connector s.gif PCI expansion
N/A Memory
From 1.0GB to 2.0GB DDR2 SDRAM s.gif Memory
From 512MB to 2.0GB DDR2 SDRAM Hard disk drive(s)
Up to 160GB 5400 rpm Serial ATA hard drive
Price $789.99*
regards-balisonu79
Feb 15, 2008 | Computers & Internet
Toshiba Satellite Driver Install Issues On XP
did you go to toshiba and see if they were listed on their website?
If so let windows put in their own drivers.
uninstall them from device manager and scan for hardware changes.
Dec 02, 2007 | Toshiba Satellite P100 Notebook
Toshiba Satellite A205-S4587 Notebook Logo
239 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
