Question about Kenmore 43042 Front Load Washer
44082400 kenmore front load washer not spinning while in final spin. I have checked the machine in dia mode and seems to work just fine. Any help would be helpful
  • 15,935 Answers
It appears your motor/motor controller or even timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
On a 417-44082400 washer how do I get the dial indicator out?
Try this site - very helpful and had parts I needed. No, I am not associtaed with them - just satisfied customer. Got help and parts for Kenmore washer and dryer.
Washing Machine Repair Help
Apr 26, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
It seems like there have been too many problems with this washer, Kenmore 417-44082400, I had my old washer for 15 years and had no serious problems Montgomery Ward brand. Everytime I run a load the washer...
once the tub starts wearing out on the mounting supports (kenmores) tend to have that problem i had to take mine apart finally and change the springs and mounts to make it stop shtting dwon
Jan 14, 2010 | Washing Machines
Kenmore 110 Spin Cycle
Assuming that this is a basic top load, direct drive, neutral drain washer it seems as if the problem is likely in the timer.
The transmission and draining are controlled by the motor which gets it's power through the timer. If the timer isn't advancing once it gets to the spin cycle area, the motor keeps getting power, the machine keeps spinning and only by pushing in the control knob will the motor stop.
Here are a couple of places to look at how the machine works and parts for a basic Kenmore washer.
Sears parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a number of sub catagories for the washer components.
Whirlpool Installation and maintenance PDF.
This is a public domain Whirlpool manual describing how the washer works and a good troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 21, 2009 | Kenmore 22642 Top Load Washer
Kenmore front load washer 417-44082400
Check your ettings
one of them has been changed
try using different settings till you get the right one back
otherwise your timer my be malfunctioning
Jan 18, 2009 | Washing Machines
My kenmore front load did that just a few months after I bought it. Unfortunately it was the the electronic board {brains of cycles} that had to be replaced. Had to replace it 3 times!! Warranty did cover it. Look into your warranty--at that time the boards were $200-$250 each!!
May 13, 2008 | Kenmore 43042 Front Load Washer
Kenmore HE2 Front Loading Washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 24, 2008 | Kenmore 46462 Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Kenmore 43042 Front Load Washer Logo
137 people viewed this question
Sal De
fordexpert
Robert Rankin
