Question about Nokia 2630 Cell Phone (Unlocked) - Black
Need to activate bluetooth
But my screen is broken so i need detailed instructions on how to activate. ie: menu, down 1 across 1 ENTER, down 2 etc.. can u help me
  • marcelinaust May 02, 2009
    broken display, want to download the data via BT, therefor I need detailed instructions like, one down, press ok etc.
    Problem Solver:
  • 4 Answers
Master Code : 3373605146
Posted on Feb 18, 2009
Set up E mail account LG S310
Follow the below mentioned steps :
1.
In the main menu touch the Messaging shortcut - the one with the envelope as an icon - at the bottom of the screen
View - Messaging settings
2.
In the Messaging menu scroll down and click on Settings at the bottom of the list
View - Messaging - Email
3.
In the Settings menu click on Email
View - Email settings
4.
In the Email menu click on Email accounts
View - Add new email account
5.
In the Email accounts menu click on the icon at the bottom left of the screen and select Add new
View - Enter email account details in the form
6.
You will need to enter all your email account information - name, email address, email servers, log on details etc. - into the online form
View - Email accounts
7.
Your new account should be listed in the Email accounts menu. Click on the Activate button to get started.
In case of any additional help please reply back.
Jun 12, 2011 | LG GD510 Cell Phone
I can't activate the bluetooth on a samsunh sgh j700
You can activate the bluetooth for this phone by following the instructions below as they come to you. If you are not clear on any part, please contact me.
1. Go to the main menu of your phone.
2. Scroll through to the application menu,
3. Open it and select bluetooth. From here, you can activate the bluetooth feature on your phone.
You have to follow the above instruction if you want to receive an item from another phone via bluetooth. Sometimes, you might be asked to pair your phone using a code, this is normal depending on the phones involved.
Also, if you want to send an item from you phone to another phone, all you need to do is to select the item and press the options button and select "send via" and the choose bluetooth from the menu.
Hope this was helpful? Please remember to check back with me if you are not sure of anything and I would explain better, Thank you for using FixYa.
May 19, 2011 | Cell Phones
I cannot locate my owners manual for my Imperial upright commercial freezer. I need to know how to defrost it
Hi the following should tell you all the info about the controller
Directions for Accessing and Setting G3 Series Digital Controllers
Changing the Temperature
Instructions for changing the desired temperature
1) First, press set for 1 second
The current set value will begin flashing after a few moments
2) Second, increase or decrease the temperature value by using the up or down icons
3) Lastly, press set to confirm the new value
Manually Setting Defrost
Instructions for manually setting automatic defrost
1) Press down the snowflake icon for more than three seconds
note that defrost will only begin if the temperature inside is equal to or less than 45
degree F.
2) Defrost will last about 25 minutes and then return to normal cooling or freezing
cycles.
Using Flash Cooling or Freezing
Instructions for Using the Flash Cooling or Freezing command
1) First, press the up and down icons together for more than 3 seconds
2) The refrigeration unit will immediately begin cycling to quickly reach the desired
temperature set point.
3) ** Flash Cooling/Freezing Option must be first set on the Configuration Parameters
Menu: Go to CC (continuous cycle duration) and enter a value. The value entered will
be the amount of time (in hours) the Compressor will run continuously to pull the
temperature down. Note: Flash Cooling may go below the temperature set point.
Eg. CC = 2 = 2 hours of Flash Cooling/Freezing.
Accessing & Setting Configuration Parameters
Instructions for Accessing & Setting Configuration Parameters
1) First, press set for 3 seconds, the display will show PS, then press set again.
2) Next, enter the password #22 to go the menu, press set.
3) You can scroll within the menu by pressing the up or down icon.
4) Go to the Carel controller detailed menu chart for specific controller settings. Click
Here.
5) To change the values, go to the menu listings ( C0, C1, D0, D1, F0, F1 etc), press
Set, the up or down icon, then Set again to complete the changes.
6) Finally, to Save all the changes made in the Menu, press and hold Set for 3 seconds.
Note: One of the parameter menu listings must be accessed to Save properly by
pressing set for 3 seconds. Saving by pressing Set for 3 seconds outside of the
parameter menu listings (ie, CO, C1, DO, D1, etc) will not save the changes.
7) If you do not want to Save the changes made, do not press the buttons for 60 secs
Regards
Gordon
Apr 22, 2011 | Migali Imperial Series Aluminum Reach In...
Unable to perform bluetooth at nokia 7610 mobile
To activate BT, try the following:
1 Press Menu, press Connectivity, and then press Bluetooth. 2 (Optional:) Enter a custom name for your phone, and then press OK. 3 Set Bluetooth to On. 4 Set My phone's visibility to Shown to all. 5 Press Exit to return to the previous screen.
When sending, choose a file you'd like to send, click options, and then send via bluetooth.
Jan 12, 2011 | Nokia 7610
Have broken the screen on my motorola V360v. Need help
Wish I had one of those lying around. Best I could say would be to Look on page 6 of the V360 Manual. If you can get into the Settings Menu then you just need to go down 2 and select and then down 1 and select and you'll be in the USB settings menu. If you remember how to get in the Main menu, it's usually down one and right one to the settings menu.
The phone is also supported by the Motorola Phone Tools program.. There is an option to transfer your phone book to another phone on the Motorola Phone Tools Welcome Screen. (I think it just takes a couple of clicks with your mouse to get r' done.
Go to this website and sign up. (Easy as 1-2-3) Oncy you verify your email address, log in to the site and you will be automatically directed to the Motorola Phone Tools Download page where you can download the program for free. You'll need a Windows PC, a data cable (you may be able to use Bluetooth) and you'll also need to download and install the USB Windows drivers as well. Here's the link:
http://motoroladownloads.webs.com/
Apr 08, 2010 | Motorola Mobility V360 Cellular Phone
How do you get the password off of the
There are two ways to reset the boot or the bios password:
1.By removing the CMOS battery
You have to shut down the computer , disconnect the power plug and open up the unit and locate the CMOS battery ( which usually looks like a coin) . Carefully lift the battery out of its socket and set it aside.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
2. By using the motherboard jumper
Shut down your computer and disconnect the power plug. Identify where the jumpers are located. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. Then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down! Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.
For detailed instructions and snapshots u can check up this link :
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Mar 15, 2010 | Computers & Internet
Cellphone will not detect bth-015b
Bluetooth technologymag-glass_10x10.gif is a wireless means of sending and receiving data over short distances with mobile and stationary devices. While it has applications in non-civilian work, such as military and space organizations, bluetooth can be found on everyday items such as laptops, computers, cellphones and their accessories. These days, the need for a more hands-free alternative to the use of cellular phones is important; not only for ease of use or increased productivity, but for general safety. In some areas, the use of a bluetooth device while driving has become a law to protect other drivers and the public from accidents
  1. tep 1 Fully charge your bluetooth headsetmag-glass_10x10.gif according to its instructions. This can take from 1 to 4 hours, depending on the model. This can be done through the included AC adapter, car adapter or USB connector cable to your computer.
  2. Step 2 Unplug your bluetooth headset from the charger. Hold down on the control button, the large lighted button on the face of the device, until it blinks red and blue. It's now in pairing mode.
  3. Step 3 Turn on your cellphone. Enter the menu screen and navigate to the "Settings" screen. Search for an option labeled "Bluetooth" and select it. You will be prompted if you want to turn bluetooth connectivity on. Press "Yes."
  4. Step 4 Search for the bluetooth headset with your phone by going into the Bluetooth options screen and selecting "Search." The headset should appear under a list of found devices, usually called "LG Headset." Select the headset.
  5. Step 5 When prompted for a passkey, enter the numerals "0000" without quotations and press "OK." Your LG headset should now flash blue, indicating that it is paired with your phone.
Nov 17, 2009 | Cell Phones
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
Cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
Connecting Bluetooth to Kenwood KDC X590
you need a kenwood kca-bt200 which is a bluetooth plugin for your head unit. when you have installed this here is a check to see if its recognised.
1 Select the STANDBY
Press the [SRC] button.
Select the "STANDBY" display.   2 Enter Menu mode
D-1:Press the [MENU] button for at least 1 second.
D-2:Press the [MENU] button.
D-3:Press the [FNC] button.Turn the Control knob to select "MENU", and then press the Control knob.
"MENU" is displayed.   3 Select Bluetooth device selection mode
Push the Control knob towards up or down.
Select the "Phone Selection"/"PHONE SEL"/"PHN-SEL" display.   4 Enter the selected Bluetooth device selection mode
Press the Control knob for at least 1 second.   5 Select the KCA-BT200 Firmware
Select the "BT200 FW ***" display.   6 Exit the Bluetooth device selection mode
D-1/D-2:Press the [MENU] button.
after this you should be able to pair from the headunits menu
Nov 27, 2008 | Car Audio & Video
Nokia 2630 Cell Phone (Unlocked) - Black Logo
299 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
