The light comes on saying its a E with out the top washer
Lg front loader
    Scholar:
  • 99 Answers
This is joyce
Very easy solution go to lg.com and download your manual to your codes and this should tel you why you have the e code, it may say you are not getting enought water in machine, sometimes slow water will cause this code, try first reseting machine, unplug from wall for 1 min, then replug in wall and see if it goes away. if it dont you may have to call techn, these machine's are not easy to work on by yourself they are very exspensive if they are new, if you want to take chance go for it, the manuel will help.
let me know if I can be of help.
thanks
joyce
Posted on Feb 13, 2009
Lg front loader will turn but not spin. help
Unplug the unit remove the top look for the servicers book this will help u at least find the code if no code then you need to contact lg to have a servicer come out and take a look
Sep 25, 2011 | LG WM1814CW Front Load Washer
My front loader LG washer works fine during the load, but when I come a while after the load is done, water has seeped back into the washer and I have run the drain cycle to get it out. LG says it needs...
If you have the capability its probably a leaking seal on the water input line at thetop of the water. Often its a simple hoseclamp that needs tightening. Without looking myself thats the easiest solution. Hope this helps!
May 09, 2011 | LG WM-2277HW Front Load Washer
Le Error on front load machine
Hello,This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged. Usually this small door is on the left side front below of your washer. Expect some water to come out when you open the door, etc. Clean out your filter and refit.....things should be fine.
Thanks
May 22, 2010 | LG WM-2277HW Front Load Washer
How do you remove the top on a LG WM2077CW front loader?
I can not remove the top cover of my LG WM-2277HW
can somebody tell me how to lift off the top cover. I already
removed the screws from the rear
Nov 09, 2009 | LG WM-2277HW Front Load Washer
Front-load washer doesn't clean!
I don't know anyone who thinks the front loader is better except for stacking things on top of...
Certainly the performance of the modern water-saving front-loader is questionable when compared to earlier models - which is why I think a wash takes much longer these days with a modern machine, I think it has to in order to be effective. My friend's new front loader can take a couple of hours to complete a programme and it is only a washer and not a waser/drier.
The older washers used to take everything that could be pushed inside and the laundry would emerge smiling. These days overloading is a complete taboo and should be weighed to ensure nothing is strained.
Your washer might have a fault but in the final analysis you made a contract with a retailer to, in return for a consideration, supply you with a washer to clean your laundry. The supplied washer doesn't clean the laundry in spite of your best efforts and that means the retailer has broken the contract. It is up to him to sort matters out to your satisfaction.
Mar 25, 2017 | LG WM2016C
Need to replace calypso washer...sugestions
The mold problem is from too much detergent usage.  Manufacturers recommend only 2 tablespoons of detergent per wash to avoid any mold issues.  It may not say it in the owners manual but it is from the manufacturers themselves.
Jul 18, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
