Question about HP Photosmart 3310 Printer
My printer is not working, I am receiving error # oxco5d2281
My printer is no longer printing. First it stopped printing the right color, then it just printed blobs. Then it just stops printing and gives me error # oxco5d2281
5 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: HP COLOR LASREJET 3500 41.3 ERROR
Check your settings under the properties menu. and in the software your using.
Posted on Jun 26, 2007
rosener
  • 103 Answers
SOURCE: Ink blobs on edges of printouts
Dear sir,
I figured out this problem it may cause; The problem behaves strangely why only on the right section the printout is not fused. The common section I first check is the high voltage circuit causing no static properties the powder shall be fused with the drum's developer. Now, it is clear also that the cause is within the drum. Pls check drum's life by printing the machine diagnostic details to check all moving and consumables counters. Clean the drum by rotating the developer roller. Well see if there's a irregularity of powder distribution. Have a nice day.
Posted on Feb 06, 2008
acdr
  • 1913 Answers
SOURCE: ''Page too complex'' message on HP color laserjet 2840 Multifunct.
go to printer and faxex then enable advanced features in your printer po\roperteis.
Posted on Nov 15, 2008
SOURCE: HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Posted on Jun 18, 2009
SOURCE: HP Photosmart 3210 all in one
google it
Posted on Dec 22, 2009
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    My Lexmark X2670 has stopped printing on my MacBook and I receive the following error message Missing component: /Library/Printers/Lexmark/Drivers/.Resources/2600 Series Color 2.lut How do I fix this
    go to applications, utilities, and open terminal in the window, paste this: open /Library/Printers/Lexmark/Drivers/.Resources/ It will open the folder where the missing component should be. You will find the "2600 Series Color 1.lut" file. Duplicate it and change the name to 2600 Series Color 2.lut close the folder, and shoot a print, it should work.
    Mar 07, 2011 | Office Equipment & Supplies
    Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
    Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
    Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
    Cartridge Error 50C consult user guide. I
    Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
    Your print cartridge has shorted.
    1. Power off your All-in-One and unplug it.
    2. Plug in your All-in-One again and turn it on.
    3. Uninstall and then reinstall your cartridges.
    4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
    Error: Black Cartridge Missing
    The black cartridge is not installed. (Install cartridge PN 82)
    Error: Color Cartridge Missing
    The color cartridge is not installed (Install cartridge PN 83)
    Cartridge Error
    Complete the following instructions:
    1. Power off your All-in-One.
    2. Use both hands to lift up the scanner unit until the scanner support holds it open.
    3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
    4. Remove the color print cartridge.
    5. Lower the scanner unit until it is completely closed.
    6. If the error message reappears, replace the black print cartridge with a new print cartridge.
      If it does not repeat steps 1-3 and then go to step 7.
    7. Reinstall the color cartridge and remove the black print cartridge.
    8. Lower the scanner unit until it is completely closed.
    9. If the error message occurs again, replace the color cartridge.
    10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
    11. Lower the scanner unit until it is completely closed.
    12. If you receive the error message again, replace both cartridges.
    Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
    Error 50 c
    1. Power off your printer.
    3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
    Hope this helps.
    Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
    hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
    RK2-0247-000CN
    chris
    May 27, 2009 | HP Color LaserJet 3500 Printer
    Printer light blinking
    Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
    Product
    --> Lexmark Z615 Country / Region:
    Country / Region:
    --> United States Language:
    --> Language:
    English Need to download
    a driver?
    --> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
    1. First count the number of times the light on the front of your printer flashes.
    2. Then refer to the table below for information about the error condition and recommended recovery procedures.
      Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
      The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
      4 Print Incomplete:
      The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
      12 Cartridge Short:
      The printer has detected a short circuit in a cartridge.
      1. Turn the printer off.
      2. Open the front cover.
      3. Turn the printer back on.
      4. Remove the color cartridge.
      5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
      6. Remove the black cartridge and then reinsert the color cartridge.
      7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
      8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
    Apr 22, 2009 | Lexmark Z640 InkJet Printer
    I have a Lexmark x1100 Series printer and cannot print anything now. This printer has been working but it stopped printing. Do not have the CD.
    Need more info. Any error messages? Did it just stop pumping ink on paper. Are you trying to print black text or color picture? If no error, your cartridges may be empty. If black text does not work, try color picture. Usually one cartridge goes empty and the other still has ink. If color pic prints replace black cartridge. If neither black or color prints at all, it may be a toasted printhead
    If you need to reinstall the software, uninstall it, then go to lexmark.com and get new drivers from their site. RESTART COMPUTER! Reinstall from the downloaded file.
    If all the above fail to make it work, it is hosed, shop for new printer.
    Dec 09, 2008 | Lexmark Office Equipment & Supplies
    Print Cartridge in Right Stall not Supported.
    print cartridge colour ink is not workink fix with hp print
    May 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
    No longer prints in color
    check that the cartridges is installed correctly, print demo page prom printer. if its B/W choose quality in menu and color mode there you can switch B/W and color printing
    Dec 16, 2007 | Konica Minolta magicolor 5430 DL Laser...
    HP Photosmart 3310 Printer Logo
    Vinaya Kumar...
    Vinaya Kumar...
    Seeker5211
    Seeker5211
