Question about Euro-Pro Shark GI490 Iron
My irons leaks
I have purchased many irons, within about six months each of then begin to leak from the bottom. I have clean it with bake soda and soak same into water. I need help
  • DAT55 Apr 01, 2009
    Shark Steam Iron Model G 1405Z. It's anti leak and anti-calc. Whatever that is. My shark steam iron leaks also! It leaks from where you put the water in the top and from the bottom corners. This is the third one that I have bought. But, I paid a lot more for this one hoping that it would be better, It's not!!!!!!!!!! What in the world is going on?????????????
  • 134 Answers
Hi
You obviously live in a hard water area and use the iron a lot.
Try using distilled water only. You can get this from motorists shops, they use it for topping up batteries.
please leave feedback
THANKS
Posted on Feb 13, 2009
How can I clean the ceramic sole plate of my iron
Follow These Steps
  1. Mix water and baking soda. Make a paste of 1 tablespoon water and 2 tablespoons baking soda.
  2. Apply the paste to the iron. ...
  3. Wipe iron clean. ...
  4. Clean steam holes. ...
  5. Re-fill the reservoir. ...
  6. Turn on the steam. ...
  7. Pour out the liquid.
How to Clean an Iron Video and Steps - Real Simple
https://www.realsimple.com/home-organizing/cleaning/laundry/clean-iron How can clean the ceramic sole plate of my iron Google Search
Oct 26, 2017 | Irons
Someone tried cleaning the iron with baking soda and water, how do get all the baking soda out of the iron, when I use the steam button it still has baking soda coming out. Thank
Mix some vinegar with water and pour it in, the reaction will get rid of the baking soda, then rinse with clean water. NOTE: the reaction produces carbon dioxide gas (NOT carbon monoxide which is the one that kills people!) so its safe to handle and be around, but it will also froth and bubble up so its best to do it outside or over a sink. Add only a small amount of the solution at a time and you'll see what I mean, and you'll know how to proceed if you need to add more.
Mar 10, 2015 | Irons
Sharper image humidifer ev-hd10
follow this steps and fix it. God bless you
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 28, 2013 | Irons
Tefal steam generator iron
  1. Unplug the iron.
  1. Unplug the iron.
Nov 24, 2013 | Irons
Water is leaking out of the bottom of my philli[s GC 9240
see the next steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
  1. Unplug the iron.
  1. Unplug the iron.
Nov 14, 2012 | Irons
How can I clean a burnt mark on the stainless steel iron
I have used the following for various iron cleanings. None have damaged my irons. Baking soda
Dec 16, 2011 | Rowenta Irons
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
Leaking iron
Here is a tip that will help tou figure out your problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Apr 24, 2010 | Rowenta DZ1900 Iron
How to cean bottom plate with spray starch on it
Rowenta has a cleaning kit found where the irons are displayed.
Faultless Hot Iron Cleaner can be found in the laundry area.
Dritz Iron-Off is with sewing notions.
You can also use a damp cloth dipped in baking soda, but the above listed cleaners will work faster and better.
Apr 08, 2010 | Rowenta Effective DX1900 Iron with Auto...
Need to know best way to clean; inside & ironing surface. thanks, Glenn
It depends on what "gunk" is on it.
If you've been using the iron for doing laminate adhesive (contact cement) you would need to use lacquer thinner.
If it's just dirty from common household ironing duties you could use baking soda and vinegar.
Apply with a q-tip,or with the iron unplugged,you could fill a shallow pan with the solution and carefully lower the bottom of the iron into it.
For baking soda/vinegar use approx 1 tsp powder to 1/2 cup vinegar.
For the inside of the iron use straight vinegar.
Pour vinegar into the water fill hole,shake gently,let sit for about 10 minutes,then rinse with water. Hope this helps.
Sep 24, 2009 | Rowenta Professional DE880 Iron
Euro-Pro Shark GI490 Iron Logo
398 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
