Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
60PP920217F Convergence Problem?
I've read about the convergence problems and what to get to fix them, but I'm curious if that is where I should start. I got the tv from the couple that bought it new, and they had apparently had the convergence fixed on the tv once already. Then, a few weeks later, the tv messed up again. They called the same repair place and the guy said that it was the same issue and quoted them like 400 to replace the board.
I got the tv home and plugged it in and all it does is chirp and the power button lights up red.. Any ideas on where to start? This is my first time in a tv, but I have alot of experience- mechanical and electrical with automotive applications as well as being a senior mechanical engineering student.
  • 1 more comment
  • Beck
    Beck Feb 13, 2009
    I read some of the other posts about this tv set, so I unplugged cable 1516 and the tv screen lights up for about 5 seconds. Is the tv-kit-011 what I need to fix this issue? I will check the resistors also. What all is included in the kit? Would I be better off just getting the chips and the resistors?
  • Beck
    Beck Feb 13, 2009
    where can I buy the STK's? is that what comes in the tv repair kit?
  • jacksoneresa Feb 27, 2009
    i have all the above wrong with my tv.
    President:
  • Philips Master
  • 1,779 Answers
First- On the conv bd. check all the resistors I beleive most of the bias res. are 6.8 ohms, they are usually paired that would mean 3.4 ohms. Any that have changed in value must be replaced, we use 1watt/2%. That set should have lasted a lot longer than two weeks. Probably bad resistors that were not replaced. You will have to replace the STK's again.2- (STK392-120 ? ) Let me know and hope this gets you started.
Posted on Feb 13, 2009
  • Jim Krause Feb 13, 2009
    That's the +15 and -15 volt source for the IC's. That's why it will start temporarily. That rail also has IC2 bus line on it that monitors the fact everything is ok and of course it is not so it tell Mr Micro to shut down. I don't recommend you buy the board, reason being, if you have never done a complete convergence with the template you'll never make it. It's best for you to try and repair the old one. Let me know..
  • Jim Krause Feb 14, 2009
    The numers are on the IC's, you can try Encompass Parts,,,,MCM Electronics,,,MAT Electronics.
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be repla60PP920217F Convergence Problem? - 2c07611.pngs a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Convergence problem please help
You likely did not do all the steps required to fix it. If you bought a complete repair kit from sites such as Tv Repair Ktis go back and ask them for help. If you did not get one of their kits you can still purchase just the convergence repair instructions.
Jan 05, 2012 | Hitachi 53UDX10B 53" Rear Projection...
I have a Philips 60"
The set will need a convergence repair kit. Or to turn the red CRT off you can turn the screens down on the red CRT untill it shuts off, But the set will have a very blue or green picture and will not be very good to watch. A convergence repair kit is the best way. You can get the repair kit with instructions from www.tvrepairworld.com
May 05, 2011 | Philips 60PP9202 60" Rear Projection...
We have a philips projection tv 60PP920217F we can not alighn the blue color the picture is concaved on bottom and top
This is a convergence problem and can be repaired by replacing the two STK-392-120 convergence chips and adjusting the set with the original remote control
I have specific instructions for this repair from start to finish.
SD TECH
Feb 16, 2010 | Philips 60PP9202 60" Rear Projection...
Convergence issue with samsung HCP4752W
When you change the convergence board you must do a complete factory alignment. If you have never done this, do not attempt it, call a svc. co. You won,t regret it. Just curious, why didn't you repair the original?
Mar 23, 2009 | Samsung HC-P4752W 47" Rear Projection...
Where to buy the convergence board of a 55PP9502
You can find a replacement auto convergence board for a model # 55PP9502 from this major Philips part distributor at the following link:
Philips 55PP9502 Replacement Part Auto Convergence Board
Feb 02, 2009 | Philips 55PP9502 55" Rear Projection...
Convergence contols on Philips 60PP920217F
You have bad convergence amps and most likley 2 bad resistors in the convergence circut.
Jan 10, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp920217f My TV has a problem with the red and blue convergence. I am unable to adjust
The problem you are having is with your convergence amps your set uses STK 392-120's if you replace them you will get your convergence adjustment back, Philips part number is 932212344682
Aug 13, 2008 | Televison & Video
Phillips 60PP920217F Convergence Problems
You will need two STK392-120 Convergence ICs and about 4 6.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the job yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jul 17, 2008 | Philips 51PW9363 51" Rear Projection...
PHILLIPS BIG SCREEN TV IS BUTTERFLIED
Are the colors out of alignment and unable to converge back? If so its the convergence ICs need replacing. If the convergence isnt out of alignment you have whats called a pincushion problem. If you would like a link to where you can obtain the service manual for this model let me know.
Mar 17, 2008 | Televison & Video
Convergence problem
At present, bad connect(s) on red convergence IC. Soldering pins will fix temporarily.
Usual fix = replace STK392-110  IC's. A 400.00 dollar repair at
your local tv shop......T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
198 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
