Question about Apollo Economy In - Ground Solar System
Need a wiring diagram
I am looking for a wiring diagram for a ten year old apollo spa. The number i can find are:
26-Z604N8Y-5-AP
Serial # BA95110-008
Thanks
  • Anonymous Mar 22, 2014
    The heat on my Apollo spa won't go past 89
  • 520 Answers
Apollo Spas Head Office Need a wiring diagram - printbutton.png con_address.png 1233 Andover Park East Tukwila WA USA 98188
con_tel.png 1-800-441-SPAS (Need a wiring diagram - con_fax.pngimg src="http://i.fixya.net/uploads/images/con_fax.png" alt="con_fax.png" class="h_mi" /> 206-575-2870
Posted on Feb 13, 2009
  • Bob Citizen Feb 13, 2009
    second phone number is their fax number.
    Top Expert:
  • Apollo Master
  • 7,200 Answers
See inside of power box inside should be schematic
Posted on Dec 05, 2017
Where do I get set of hinges for dust cover of AKAI AP-X1 turntable
Check on ebay for that tt and maybe someone has parts listed. Or try the manufacturer but if a unit is more than ten years old parts are usually no longer available.
Nov 22, 2015 | Audio Players & Recorders
Have a Harrington & Richardson 410. Model 088. Serial number a2435440. How old is it. Please help. Thank you
icon1.png Harrington & Richardson date codes
Year
Serial Number
Prefix
Year Serial Number
Prefix
Year Serial Number
Prefix
Year Serial Number
Prefix
1940 A 1953 N 1966 AC 1979 AT 1941 B 1954 P 1967 AD 1980 AU 1942 C 1955 R 1968 AE 1981 AX 1943 D 1956 S 1969 AF 1982 AY 1944 E 1957 T 1970 AG -- -- 1945 F 1958 U 1971 AH* -- -- 1946 G 1959 V 1972 AJ -- -- 1947 H 1960 W 1973 AL -- -- 1948 I 1961 X 1974 AM -- -- 1949 J 1962 Y 1975 AN -- -- 1950 K 1963 Z 1976 AP -- -- 1951 L 1964 AA 1977 AR ** -- -- 1952 M 1965 AB 1978 AS -- --
Available for Cabinet level positions, consultation on matters of foreign policy, weddings and bar-mitzvahs. Will work for gold or guns.
Nov 19, 2014 | Optics
I have Electrolux front load wahser Model EIFLW55HIW0 that is about 6 years old, Has worked without a problem for many years. recently started giving E35 error codes. the water doesn't ap
Hello friend, thank you very much for your inquiry!
After reviewing the information you have provided regarding your Electrolux front load washer EIFLW55HIW0 having an E35 error code, I have found E35 is an indication of a water over fill problem. If the water fills above 4.5 inches please follow the below trouble shooting steps I have provided for you. If the water is not above 4.5 inches you may need to change the pressure sensor switch.
If the water enters continuously please unplug the washer to see if the water stops. If the water does not stop your issue may be the water valve assembly. If the water does stop the wiring to the water valve assembly needs to be checked. If the wiring is good the control board may need to be replaced.
I do suggest you seek a professional technician to look into this issue further to avoid any unnecessary part purchases. - T
Sep 28, 2014 | Electrolux Washing Machines
Need 91 holden apollo stereo wiring diagram or wire colour codes.
We have access to many radio diagrams but his is not one of them because this isn't a make sold in the USA.. See if a local source has the info. We are a US based site
Jun 28, 2012 | Holden Apollo Cars & Trucks
I have a husqvarna model 45 the serial number is 0090026 how do I tell what year it was manufactured ?
Before the year 200, the first digit would denote the year of manufacture, and the second two digits the week within that year, the final numbers would be the number of machines produced in that year, that week. up to that machine, this was done in a ten year rotation, so 0 could be 1980/1990, so i would say your machine was produced in 1990 week nine, and was 26 off the production line.
May 04, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
This is an old hot tub qca jewel spa that runs all the time
your ozonator may have condensation water in it, try unplugging it and using a hairdryer to dry it out, otherwise you will need a replacement ozonator (i know where to get these at dealer cost if you need one). When replacing ozonator, make sure you request the correct plug type depending on if you have the white plugs or gray plugs that plug into either the side of your spa pack or the circuit board.
Good job on isolating the problem by unplugging each component when a circuit breaker trips. Next, your filter cycle is most likely set on constant filtration, you will need to reset it to 2-4 hours per 12 hour cycle. Don't put it in standby, leave it run in standard mode. Hope this helps,
Spafixer
Mar 20, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
The Maytag washer is 26 years old. The problem is
Sounds like the timer motor may be dead. Can you hear it ticking when it is on or can you see the gear on the timer motor shaft turning when it is running? If not then the timer should be replaced.
Jan 16, 2010 | Washing Machines
Need a wiring diagram/pin up sheet for Fujistu ten radio up
Request the wiring diagram directly from Fujistu.
Jan 13, 2018 | Car Audio & Video
Apollo Economy In - Ground Solar System Logo
643 people viewed this question
Top Apollo Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Apollo Pool and Spa Expert? Answer questions, earn points and help others
