Question about Samsung TV Remote Control
Directv remote increases volume slowly
Directv dvr remote has to be pressed repeatedly to increase the volume on my new Samsung 46 model 850 HD. How do you get it to smoothly increase when button is push
  • 3 more comments
  • jerrylne Feb 13, 2009
    We bought a new samsung HDTV. To change the volume on the remote that came with the tv or with the remote for a Sony blu-ray player, you simply hold the up or down button. The volume goes up or down until you release the button. On the Directv remote RC64 which is coded to the tv, you can't just hold the button; you have to repeated press and release to get the volume to change. I was hoping there was a hack code that would change this
  • Anonymous Mar 01, 2009
    I have the exact same issue, any ideas?
  • jerrylne Mar 11, 2009
    It worked perfectly. Thank you
  • Anonymous Apr 27, 2009
    The solution worked for me too! Thanks!
  • albert getty
    albert getty May 11, 2010
    please ask for Premium-Assistance:
The Direct TV remote has to be programmed properly. See the user manual for the process. The problem is, the user manual tells you to enter a code for the TV, but gives you a long list of codes that may work. So it's simply a problem of trial and error. For me, the first code in the list gave me the same results that you got (having to press volume repeatedly). But when I programmed the 2nd code in the list, pressing and holding the volume worked!.
I can't guarantee it, but I suspect you'll have the same result.
Posted on Mar 07, 2009
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
Remote codes for directv HD DVR and westinghouse tv
2. Locate the 5-digit code for your TV (see pages 13-16).
3. Move the slide switch to TV.
4. Press and hold in the MUTE and SELECT keys at the same
time until the green light under the TV icon flashes twice
and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of TV. If performed correctly the green light
under TV will flash twice.
6. Aim the remote at your TV and press the power key
once. The DIRECTV Receiver should turn off. If it does
not turn off, repeat steps 3 and 4, trying each code for
your brand until you find the correct code.
10463, 10623 Westinghouse 00002 dvr hd
Jun 20, 2010 | Sony STRDH810
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
1TB Cavalry eSATA drives
DID you chk the data transfer speed ??
Mar 05, 2008 | Computers & Internet
Direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Vizio and the directv dvr
Vizio recommends using code 11758 or 10178 for Cable/Satellite universal remotes that use five digits such as DirecTV. For four digit Cable/Satellite universal remotes , use 1758 or 0178. For three digit Cable/Satellite universal remotes, such as Dish or Echostar, use 627. These codes typically make the Power, Volume and Mute functions work.
Jan 13, 2008 | Televison & Video
TV only will play HD Channels
This must be the setup for your TV box. Contact the support for your TV box.
Normaly, the TV should auto select the proper operation mode.
Jerry G.
Dec 25, 2007 | Samsung LN-T4665F 46 in. LCD Television
Hi
Have questions about your upgrade? We've got the answers. What do I need to do to receive my upgrade? Nothing! Just make sure your DIRECTV HD DVR is continuously connected to your land-based phone line and you will receive the upgrade automatically. When will I receive my upgrade? The 6.3 software upgrade will roll out over a period of several weeks. Customers with more than one DIRECTV HD DVR may receive their upgrades at different times for each receiver. We appreciate your patience while we deliver these new and improved features to eligible DIRECTV HD DVR customers nationwide. Are all DIRECTV DVRs receiving this upgrade? No. DIRECTV DVR models SONY SAT-T60, PHILIPS DSR6000R and HUGHES GXCEBOT will not receive the 6.3 software upgrade. Other models received a similar upgrade, 6.2, in the past. I have a DIRECTV R10 DVR with 6.1 software. Will I receive this upgrade? No. The 6.1 software on the DIRECTV R10 DVR already includes the 6.2 features such as folders and faster menu scrolling. Will any of my DVR settings be changed as a result of the upgrade? Yes, some of your settings or preferences will be changed back to the factory default settings as a result of the upgrade. These include: "Favorite Channels," "Channels You Receive," "Spending Limits," "Clear Channel Banner Quickly" and "Dolby Digital" recording and output. To change Channel Banners, Channels You Receive and Favorite Channels preferences: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Channels" To change Spending Limits: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Parental Control" To change Dolby Digital Settings: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Audio" 4. Select "Dolby Digital" and "Digital Output" Will I be charged for this upgrade? No. We're upgrading your DIRECTV HD DVR as part of your normal DIRECTV® DVR with TiVo® service at no additional cost. What happens if I don't have my phone line plugged into my DIRECTV DVR? You will not be able to receive the upgrade if your DIRECTV DVR is not connected to your phone line. To install the upgrade, your receiver must successfully make a call to our servers. How will I know when I have received my upgrade? You'll receive an on-screen message the first time you visit DIRECTV Central after your upgrade is complete. It will also appear in your Messages section. You can also check your System Information screen to find out which software version you currently have. Will the download delete any of my currently saved programs? No. All of your saved programs will still be there for your enjoyment after the installation. Once your upgrade is complete... How do I activate the Grouping (folders) option? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change groups to ON. SHORTCUT HINT: While viewing your Now Playing List, press number 2 on your remote control and your Now Playing List will change from the GROUPS view to show each individual recording. Press 2 again and it will switch back to the GROUPS option. How do I sort alphabetically instead of by date recorded? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change sorting option to Alphabetical. SHORTCUT HINT: While viewing your Now Playing List, press number 1 on your remote control and your Now Playing List will change from alphabetical to date sort. Press 1 again and it will switch back to alphabetical sort. Some settings will restore to factory defaults when the new software is download
Aug 19, 2007 | RCA DRD485RG DirecTV DTV Receiver
Samsung TV Remote Control Logo
582 people viewed this question
Henry  Thomas
Henry Thomas
