Problem with 2wire (1000-000057-000) Modem
2wire 2701HGV-W Gateway wi-fi modem
How do I connect a printer to this modem so that I can communicate with it from my computers wirelessly via the wi-fi modem?
Posted by avatar on Feb 13, 2009
    • By avatarjimgiblet Feb 13, 2009
    • Hi, thanks for the quick response. I have a HP Photosmart 8200 series printer with usb connection.
      Cheers,
      jimgiblet
    • By avatardante777 May 11, 2010
    • You can connect your printer in two ways:
      1. via USB
      2. via Ethernet
      These options are depending on what kind of printer you are using.
      Please tell me which printer you have and I will be able to give you more details,
    • By avatarjasonbart Mar 13, 2009
    • i would like to know how to connect a brother mfc260c to the 2 wire modem to use as a network printer. it has a usb conection on it
Solutions (1)
Best Solution
The 8200 by itself does not have networking capability.
This means that you cannot connect it directly to your router and give it an IP address, so others can connect to it.
The good thing is, that this printer is listed on the list for compatibility for upgrade with the wireless network kit (see here). The bad thing is - this kit costs about 70$ (see here).
A solution which does not cost anything, is to share the printer from your computer with the other computers. The downside is that the machine to which the printer is connected has to be running in order to let the others print.
If you decide to buy the Networking Kit - here are the setup instructions.
Sorry - but there is no simple (plug & pray) solution.
Add Your Solution
See all 2wire (1000-000057-000) Modem Problems
