Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
When I attempt to start my Frigidaire Dishwasher (model FDB1050REB0) the washing light comes on and continues to flash but the cycle does not start. I have replaced the control module but still have the same problem. The door is latching shut with no problem but I can't imagine what else it could be. Do you think I need to replace the door latch?
  • 3 more comments
  • p_leckie Feb 13, 2009
    My washer is just over a year old and the washing light just started flashing when we press start. No idea what the problem is.
  • glennsamia Feb 15, 2009
    I have the same problem on a GE Profile Performance dishwasher.
    the "washing" light is blinking.
  • thedoors111 Feb 16, 2009
    I have the same problem. How can I fix it?
  • kpeters82402 Mar 21, 2009
    When trying to start the dishwasher the wash button just flashes on and off non-stop.  What causes this?
  • Anonymous Mar 26, 2009
    I got ready to turn my dishwasher on and it won't start. the washing light just flashes but it won't do anything else. I have tried to reset the breaker and unplug it and plug it back up and everything. Nothing works.
I had the same problem : Wash light flashing. I cut the breaker, turned it back on, held the heat / start buttons...No change. I thought of replacing the control panel but first I removed the latch. There are two contact switches kind of like old small engine points. I cleaned / lightly filed them. Reassembled and it works fine!
Posted on Dec 02, 2013
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
Posted on Mar 28, 2009
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
The hi temp wash and air dry lights are blinking on my firgidaire dishwasher
Hi Dan, this is AP!
I understand you are experiencing some trouble with the lights on your Frigidaire dishwasher. On your particular model, FFBD1821MW, if there has been a power failure, then the "Hi-Temp Wash" and "Heat Dry" LEDs will flash. In order to stop the LED lights from flashing press Start/Cancel. This process should relieve your concern regarding the LED lights flashing. I hope this information proves helpful to some degree.
Best of luck,
Mar 25, 2014 | Frigidaire Dishwashers
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
Frigidaire dishwasher stuck on wash cycle, doesn't complete - model # FDB1050reb0
This model doesn't use a timer like older types, The element is turned on and off by the electronics and a failed board can cause the symptoms mentioned, thee is no real way to test the board as the integrated electronics are quite complicated. The board is easy to replace, if you can use basic tools you would be able to manage it.
The dishwasher is cold fills so heats it's own water so the hot water temperature in the house has no impact on the dishwasher.
Mar 10, 2012 | Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
Fliped the circut breaker and got the 3 blinking lights and hit start and it ran fine.
Apr 18, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Normal wash flashing Red
We have the same problem with kenmore model 66513839k600
we press light wash and normal wash lights up, we have to wait over a month for sears to service. This will be the second control panel they will install on warranty, a month is far too long a wait for service on any appliance.
Dec 03, 2007 | Kenmore 24 in. 17039 Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
811 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
