Question about Sewing Machines
Material pulling/shifting to one side
My 4 year old decided it would be fun to play with my sewing machine and moved all the dials on me. I'm not sure exactly what he's done but I have come across many problems. I've been fussing with the machine for 2 days doing a bit of research on the internet, etc. I've changed needles, tried different threads, cleaned the parts, played with the knobs, etc. My problems (mainly nesting underneath) seem to be working out except for the fact that when I try to sew, the material seems to want to pull to one side rather than just going straight while i gently guide it. Any ideas what how to correct this problem?
  • 2cin Feb 13, 2009
    Thanks sooooo much for your help. Also it's good to know that the shifting is called drifting! I manage to find the manual for the machine that I never knew I actually had. Unfortunately it doesn't have a troubleshooting section nor does it mention what the "standard" settings should be at. I'll definately try adjusting the foot pressure now that I know which knob that is! : ) Again thanks for your response.
  • 3 Answers
Sounds like you're foot pressure is off, foot pressure and stitch length are the 2 main things that would cause "drifting" (they're also knobs that little hands could of moved) Also your little one quite possibly could of spun these knobs several times so keep that in mind while dialing your machine back to good health
Posted on Feb 13, 2009
TacsewKM1243A only sews in reverse how can i make it go fowoad ?
1. Take the top off your machine.
2. Move the stitch length back and forth and watch the arm inside .
3. By doing this you will see where the arm is connected. The arm is probably loose or stuck by old grease. Look on the arm for loose screws. Tighten them.
4. If you see old grease that is hard and dirty you will need to clean it off. Use carburetor cleaner. Use old rags and a qtip and toothbrush. (Don't brush with it anymore)
5. Recheck to see if the mechanisms inside move by the arm.
6. Put some material on the sewing machine w/o a needle or bobbin inside. Turn the hand wheel and watch the material. You will have to move the arm to different areas to see differences in the material movement.
7. Once the material is moving you can put new oil on all moving parts that touch each other. (steel against steel)
Remember loose screws, old grease are probably the problems.
Mar 28, 2015 | Sewing Machines
My very old little elna lotus (not sure if zz or sp) has suddenly jammed solid with the needle down through a piece of material. I can't move the flywheel at tall and I can't free the materia
Try unscrewing the needle, and then pull up the plate, and sort outthe threads very carefully with a quikunpick. When starting to sew, have slightly longer threads, make sure they are behind the needle, and hold them in your left hand. Especially when sewing very fine fabric, start slowly until you are sure the threads are forming properly, then it's OK to speed up. Use your ears, if it doesn't sound right, stop immediately. If you are going to use fine slippery fabric, be sure to do a trial piece first, rather than muck up your project. Elna machines are lovely to use, I've had one for over 40 years, still in daily use. Oiled with one spot of oil each time I use it, fluff regularly cleaned from underneath with the little brush supplied.
Apr 15, 2013 | Elna Sewing Machines
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
When i sew my thread keeps pulling and breaking from the needle, seems like there is a lot of pressure on top thread and it bunches up from the underneath bobbin when sewn on material
Most of the time it is caused by the top threading, Could your thread be old, or tangled? Double check your threading by this little trick, put your tension dial on 3, totally rethread, insert a new needle (flat side facing rear). Then with the presser foot up, pull on the top thead and it should pull smoothly, now put the presser foot down, pull again, it should barely move. This usually seats the thread in the tension discs. Hope this helps.
Dec 08, 2010 | Kenmore 11101 Mechanical Sewing Machine
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Aug 03, 2010 | Singer Sewing Machines
Keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
Apr 06, 2008 | White Sewing Speedylock 1600 Mechanical...
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
67 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
