Question about Samsung Digimax S800 Digital Camera
Cd-rom not compatible with windows 7 - Samsung Digimax S800 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Posted on Feb 17, 2013
SOURCE:
The CD -rom not compatible with windows 8. it works on windows 95
Between Win95 and Windows 8 there are several other versions Win 98, Win 2000, Win XP, Vista, and Windows 7. Try to run the CD in compatibility mode. If it does not work you will have to forgo the use of that software or run it on an old machine, or upgrade to a version compatible with Windows 8 if one such upgrade exists.
Aug 31, 2013 | Expert Software Computers & Internet
I would like to know what CDRom Drive is compatible with Sylvania Netbook 7"
1. if the cd rom is usb then the netbook should detect it immediately unless it is too old for the Windows 7 Operating system
2. you can check the manufacturers site of the CD ROM and see how old it is.
if it is too old it will not mount .
3. you can check the compatibility mode for the device and see if it will load under another OS ( operating system ) such as Windows XP or Vista.
4. check windows update for latest drivers
5. Here is a link for Windows compatibility:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Jul 14, 2011 | Sylvania G-Netbook
What drivers do I need to make Family tree maker Compatible with Windows 7
Start the Windows "Program Compatibility Wizard".
Tell it that you want to install a Windows XP application from CD-ROM.
Windows 7 will create a "wrapper" around the software, to make it think that it is running under Windows XP.
Nov 20, 2010 | Encore Family Tree Maker Version 16 Full...
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
My web cam can only be installed on windows xp but now i have windows vista and i can not re-install it on it, can you help me please..? web-cam is the Veo Connect personal web camera. Thank you for your...
Hi Friend,
Please follow the below steps,
Step 1. Hold down the shift key on your computer to
disable the CD from Autoplaying.
Step2. Insert the Veo Advanced Connect Installation CD-ROM & Bundled Sofware CD-ROM in your CD-ROM/DVD-ROM Drive.
Step 3. Browse to the root (first) directory of the Install CD and locate Autorun.exe
Step 4. Right-Click Autorun.exe and select Properties
Step 5. On the resulting window, move to the 'compatibility' tab and tick the box labeled "Run this program in compatibility mode for:" then select "Windows XP (Service Pack 2).
Step 6. Click "OK"
Step 7. Browse back to the executable (Autorun.exe), run it and install it as per normal.
Regards,
Aysaam
Jun 09, 2010 | Veo Connect Webcam
Having trouble installing Orbit AF drivers into Windows 7 Pro Ed.
you should use the cd to download it i bet itll work
-a person
peace love and robert pattinson
Jan 11, 2010 | Logitech QuickCam Orbit AF Webcam
My samsung software cd-rom for my S1030 digital
It is not compatible with Windows 7. You could get a card reader and download your pics to a folder you create on your desktop.
Nov 22, 2009 | Cameras
Programme does'nt open
here is the solution for your problem :
A problem has been identified when installing early pressings of the CD-ROM on machines running Windows 98 or Windows ME in conjunction with certain antivirus software and firewalls. The installation appears to be successful but the OALD 7 Compass program fails to launch with no error message given, or with a message "License data invalid".
Should you encounter this problem:
  1. Download oald7.zip (4.5 megabytes)
  2. Unzip oald7.zip to extract the oald7.exe program
  3. Ensure your OALD 7 Compass CD-ROM is in your CD-ROM drive
  4. Replace the old oald7.exe file on your computer (this is usually found in c:\Program Files\Oxford\OALD7) with the new oald7.exe file you have downloaded
  5. You should now be able to run the OALD 7 Compass software
If the download doesn't work, we can send you this file on a CD-ROM - please email us , and tell us your full postal address. You will need to copy the update file to your hard drive to install it, as you will need your OALD 7 Compass CD-ROM in your CD-ROM, as above.
Please email eltdict.help@oup.com if you require further help.
See also: more information about the OALD 7 Compass CD-ROM
For help with other Oxford ELT Dictionary CD-ROM products, see the Multimedia FAQ page.
Mar 30, 2008 | Microsoft Windows XP Professional With...
Samsung Digimax S800 Digital Camera Logo
80 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
